Reducing Data Transmission Time Using the SPT
Specify the PIM Threshold That Triggers SPT Switching
Specify the PIM SPT Switch Period
Specify the PIM RP Threshold That Triggers Source-Specific Switching
Specify the PIM RP Switch Period
Monitor the Data Transfer Rate After a Register Stop Message
Enabling Static RP Configurations
Configuring Designated Routers
Prioritize Router Messaging With PIM DR-Priority
Restore the Default Router Priority Designation
Configuring the PIM Override Interval
Specify the Interval to Delay Override Messages
Restore the Default Override Messaging Interval
Restore the Default LAN Delay Interval
Restore the Default BSR-Candidate Value
Configuring PIM Query Intervals
Specify the Hello Messaging Interval
Restore the Default Hello Messaging Interval
Configuring PIM Join and Prune Messaging
Specify the Join and Prune Messaging Interval
Restore the Default Message Interval
Configuring PIM Component Data Routing Modes
Configuring RP-Candidate Behavior
Specify the Address for the Candidate RP
Configuring RP Candidate Hold Time
Specify RP Candidate Hold Time
Restore the Default Candidate RP Hold Time
Specify the Address for the Static RP
Associating an interface with PIM doesn't necessarily enable PIM on that interface. To enable PIM over an interface, you must configure a PIM query interval (see Configuring PIM Query Intervals).
This example associates VLAN 5 to PIM 1.
SEFOS# configure terminal SEFOS(config)# set ip pim enable
SEFOS(config)# interface vlan 5
SEFOS(config-if)# ip pim componentId 1 SEFOS(config-if)# end
SEFOS# show ip pim interface detail Vlan5 33 is up Internet Address is 10.1.0.1 Muticast Switching : Enabled PIM : Enabled PIMv6 : Disabled PIM version : 2, mode: Sparse PIM DR : 10.1.0.1 PIM DR Priority : 1 PIM Neighbour Count : 0 PIM Hello/Query Interval : 30 PIM Message Interval : 60 PIM Override Interval : 0 PIM Lan Delay : 0 PIM Lan-Prune-Delay : Disabled PIM Component Id : 1 PIM domain border : enabled
