| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RMON Administration Guide |
Configuring the Ethernet Statistics Group
Enable the Ethernet Statistics Group
Disable the Ethernet Statistics Group
Configuring the Ethernet History Group
You also can configure history collection over port 2.
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/15
SEFOS(config-if)# rmon collection history 1 buckets 25 interval 30 SEFOS(config-if)# end
SEFOS# show rmon history 1 RMON is enabled Entry 1 is active, and owned by myTest Monitors ifEntry.1.15 every 30 second(s) Requested # of time intervals, ie buckets, is 25, Granted # of time intervals, ie buckets, is 25, Sample 1 began measuring at Jul 9 03:51:07 2010 Received 3124 octets, 31 packets, 0 broadcast and 0 multicast packets, 0 undersized and 0 oversized packets, 0 fragments and 0 jabbers, 0 CRC alignment errors and 0 collisions, # of dropped packet events is 0 Network utilization is estimated at 0 Sample 2 began measuring at Jul 9 03:51:37 2010 Received 3124 octets, 31 packets, 0 broadcast and 0 multicast packets, 0 undersized and 0 oversized packets, 0 fragments and 0 jabbers, 0 CRC alignment errors and 0 collisions, # of dropped packet events is 0 Network utilization is estimated at 0 Sample 3 began measuring at Jul 9 03:52:07 2010 Received 3124 octets, 31 packets, 0 broadcast and 0 multicast packets, 0 undersized and 0 oversized packets, 0 fragments and 0 jabbers, 0 CRC alignment errors and 0 collisions, # of dropped packet events is 0 Network utilization is estimated at 0
