Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System RMON Administration Guide |
Configuring the Ethernet Statistics Group
Enable the Ethernet Statistics Group
Disable the Ethernet Statistics Group
Configuring the Ethernet History Group
Enable the Ethernet History Group
The alarm group periodically takes statistical samples from variables in the probe and compares them with the thresholds that have been configured. When a threshold is crossed, an event is generated using the alarm hysteresis mechanism. This section contains procedures that explain how to create or disable alarms.
