Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
OSPFv3 Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
OSPFv3 Overview
Protocol Description
OSPFv3 Topologies
Configuration and Testing Topologies
IPv6 Example Topology Interface and Host Addresses
OSPFv3 Configurations
Default Configuration Values
SNMP MIB Files
Creating the Base Configuration
Access Global Configuration Mode
Access Interface Configuration Mode
Enabling IPv6 Support and Assigning IPv6 Addresses
Enable IPv6
Disable IPv6
Delete an IPv6 Address
Configuring IPv6 Static Routes
Configure Static Routes
Delete a Static Route
Creating the Base Configuration for Example Topologies
Configure SEFOS1
Configure SEFOS2
Configure SEFOS3
Configure SEFOS4
Configure SEFOS5
Configure SEFOS6
Configure SEFOS7
Configure SEFOS8
Configure SEFOS9
Configuring OSPFv3 Features
OSPFv3 Features
Configuring Basic OSPFv3
Enable OSPFv3
Disable OSPFv3
Creating an OSPFv3 Interface
Configure an OSPFv3 Interface
Configuring Neighbors
Configure an OSPFv3 Neighbor
Configuring OSPFv3 Interface Parameters
Configure Interface Priority
Restore the Default Interface Priority
Configure the Retransmission Interval
Restore the Default Retransmission Value
Configure Transmission Delay
Restore the Default Transmission Delay
Configure the Hello Interval
Restore the Default Hello Interval
Configure the Dead Interval
Restore the Default Dead Interval
Configure the Network Type
Restore the Default OSPF Network Type
Configure the Interface Cost
Restore the Default Interface Cost
Configuring a Demand Circuit
Enable a Demand Circuit
Remove the Demand Circuit Setting
Enable Neighbor Probing on a Demand Circuit
Remove Neighbor Probing on a Demand Circuit
Configuring Neighbor Probe Values
Configure the Neighbor Probe Retransmission Limit
Restore the Default Neighbor Probe Retransmission Limit
Configure the Neighbor Probe Interval
Restore the Default Neighbor Probe Interval
Configuring a Passive Interface
Configure All Interfaces To Be Passive
Configure Specified Interfaces To Be Passive
Restore the Default Routing Updates
Configuring Route Redistribution
Configure an ASBR Router
Disable the ASBR Router
Configure Route Redistribution
Disable Route Redistribution
Configure the Stub Area, ASBR, and Route Distribution
Configuring Attributes for Redistributed Routes
Configure Redistributed Route Attributes
Delete Redistributed Route Attributes
Configuring the Redistribution of Routes
Restore the Default Redistribution Configuration
Configuring Area Route Summarization
Area Route Overview
Configure Address Range Aggregation
Disable an Address Range
Configure an Internal Address Range
Disable an Internal Address Range
Configuring a Stub Area
Configure a Stub Area
Convert a Stub Area to a Normal Area
Configure a Default Summary Route for a Stub Area
Configure the Default Summary Route Cost for a Stub Area
Configuring an NSSA
Configure the Stability Interval for NSSA
Restore the Default Stability Interval
Configure an NSSA Translation Role
Restore the Default Translation Role
Configure Default Summary Route for an NSSA
Configure the Metric Type for an NSSA
Configuring the Capability in an NSSA Internal Border Router
Configure NSSA Type-7/-5 Conversion
Configuring Virtual Links
Configure a Virtual Link
Delete a Virtual Link
Configure Virtual Link and Route Summarization
Configuring External Database Limit
Configure the External Database Limit
Restore the Default External Database Limit
Configuring the Overflow Exit Interval
Configure the Overflow Exit Interval
Configuring a Demand Extension
Disable a Demand Extension
Re-Enable Demand Extensions
Configuring the Host
Configure the Host
Test the Host
Configuring Route Calculation SPF Timers
Configure SPF Timers
Restore the Default Delay Time
This example shows how to configure the information to be applied to routes learned from RTM in SEFOS1. The IPv6 address prefix is 3333::1111:0:0, with a length of 96. A metric value of 100 is applied to the route before it is advertised to the OSPFv3 domain. A tag with the value 10 is applied to the sample route.
  1. Test the redistribution configuration in SEFOS1.
    SEFOS# configure terminal
    SEFOS(config)# ipv6 router ospf
  2. Configure redistribution of static route's redistribution configuration.
    SEFOS(config-router)# redistribute static
  3. Configure redistribution configuration.
    SEFOS(config-router)# redist-config 3333::1111:0:0 96  metric-value 100 metric-type asExttype1 tag 10
    SEFOS(config-router)# exit
  4. Add a static route for the network.
    SEFOS(config)# ipv6 route 3333::1111:0:0 96 fec0::1111:0:2
    SEFOS(config)# end
    SEFOS#
  5. View the configuration details in SEFOS1.
    An external LSA is generated for 3333::1111:0:0 with metric as 100, metric type as asExtType1, and tag as 10.
    SEFOS# show ipv6 ospf database as-external detail
    Age: 0   Seconds            LS Type: External Lsa
    Link State Id: 0.0.0.1      Adv Rtr Id: 10.0.0.1
    Sequence: 0x80000001        Checksum: 0x6151    Length: 60
    Metric Type: Ext Type1      Metric: 0x64
    Prefix Length: 96            Prefix Options: 0x00
    Referenced LS Type: 0
    Addres Prefix: 3333::1111:0:0
    Fw Addres Prefix: 3333::1111:fec0:0
    External Route Tag: 10
  6. View the configuration details in SEFOS2.
    View the external route 3333::1111:0:0 with metric as 101.
    SEFOS# show ipv6 ospf route
    OSPFV3 Process Routing Table
    Dest/Prefix-Length   NextHop/IfIndex       Cost     Rt.Type     Area
    3333::1111:0:0/96   fec0::1111:0:2/vlan11   101     type1Ext    0.0.0.0
    fec0::1111:0:0/96               ::/vlan11     1     intraArea   0.0.0.0
    fec0::4444:0:0/96               ::/vlan4      1     intraArea   0.0.0.3
