Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
RIPng Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
RIPng Overview
Protocol Description
Configuring the RIPng Topology Example
Configure SEFOS1
Configure SEFOS2
Configure SEFOS3
General Configurations
Configuring IPv6 RIPng
Enable RIPng
Enable and Configure RIPng on Desired IPv6 Interfaces
Configuring Redistribution
Redistribution Overview
Disable Redistribution
Disable the split-horizon Option
Configuring the Debug Level for RIPng
Enable Debugging
Disable RIPng Debugging
Configure SEFOS2
Configure VLAN 10 and VLAN 40 interfaces on SEFOS2 in the example topology.
  1. Configure SEFOS2.
    SEFOS 2 SEFOS# configure terminal
    SEFOS 2 SEFOS(config)# set gvrp disable
    SEFOS 2 SEFOS(config)# set gmrp disable
    SEFOS 2 SEFOS(config)# interface extreme-ethernet 0/15
    SEFOS 2 SEFOS(config-if)# switchport access vlan 10
    % Access VLAN does not exist.,Creating vlan
    SEFOS 2 SEFOS(config-if)# exit
    SEFOS 2 SEFOS(config)# interface vlan 10
    SEFOS 2 SEFOS(config-if)# no shut
    SEFOS 2 SEFOS(config-if)# ipv6 enable
    SEFOS 2 SEFOS(config-if)# ipv6 address 1111::12 112
    SEFOS 2 SEFOS(config)# interface vlan 40
    SEFOS 2 SEFOS(config-if)# ipv6 address 4444::12 112
    SEFOS 2 SEFOS(config)# vlan 40
    SEFOS 2 SEFOS(config-vlan)# ports extreme-ethernet 0/3
    SEFOS 2 SEFOS(config-vlan)# exit
    SEFOS 2 SEFOS(config)# interface extreme-ethernet 0/3
    SEFOS 2 SEFOS(config-if)# end
  2. Show the status of IPv6 interfaces on SEFOS2.
    SEFOS 2 SEFOS# show ipv6 interface
    vlan1 is up, line protocol is up
        IPv6 is Enabled
        Link local address:
            fe80::214:4fff:fe6c:630f
        Global unicast address(es):
            Not Configured.
        Joined group address(es):
            ff02::1
            ff02::2
            ff02::1:ff6c:630f
        MTU is 9216
        ICMP redirects are enabled
        ND DAD is enabled, Number of DAD attempts: 1
        ND router advertisement is disabled
    vlan40 is up, line protocol is up
        IPv6 is Enabled
        Link local address:
            4444::12/112
            ff02::1
            ff02::2
            ff02::9
            ff02::1:ff00:12
            ff02::1:ff6c:630f
        MTU is 9216
    vlan10 is up, line protocol is up
        IPv6 is Enabled
        Link local address:
            1111::12/112
            6666::12/112
            ff02::1
            ff02::2
            ff02::9
            ff02::1:ff00:12
            ff02::1:ff6c:630f
        MTU is 9216
