Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System RIPng Administration Guide |
Configuring the RIPng Topology Example
Enable and Configure RIPng on Desired IPv6 Interfaces
Disable the split-horizon Option
Redistribution is enabled by default when RIPng is enabled. You can disable or change redistribution status, allowing more control of distributing IPv6 routes. Available options are static, connected and OSPF routes, and metrics. The following example shows a configuration with the default redistribution values.
SEFOS 1 SEFOS# show ipv6 rip RIP port 521, multicast-group ff02::9,Maximum paths is 16 Updates every 30 seconds; expire after 180 Garbage Collect after 120 seconds Poison Reverse is on Interface: vlan40 vlan10 Redistribution: Connected, Routes Redistribution is enabled.
