Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System RIPng Administration Guide |
Configuring the RIPng Topology Example
Enable and Configure RIPng on Desired IPv6 Interfaces
Disable the split-horizon Option
IPv6 RIPng functions similarly to RIP in IPv4, with various enhancements for IPv6, For more information about RIP and its features, refer to the following web sites:
http://searchnetworking.techtarget.com/definition/Routing-Information-Protocolhttp://www.pulsewan.com/data101/rip_basics.htm
