Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System RIPng Administration Guide |
Configuring the RIPng Topology Example
Enable and Configure RIPng on Desired IPv6 Interfaces
By default, the split-horizon option with poison reverse is enabled on all RIPng interfaces.
SEFOS 1 SEFOS# configure terminal SEFOS 1 SEFOS(config)# interface vlan 40 SEFOS 1 SEFOS(config-if)# no ipv6 split-horizon SEFOS 1 SEFOS(config-if)# end SEFOS 1 SEFOS#
SEFOS 1 SEFOS# show ipv6 rip RIP port 521, multicast-group ff02::9,Maximum paths is 16 Updates every 30 seconds; expire after 180 Garbage Collect after 120 seconds Split Horizon is off; Interface: vlan50 vlan40 vlan30 Redistribution: Connected,Routes Redistribution is enabled.
