Sun Blade 6000 Ethernet Switched NEM 24p 10GbE
Understanding L2 and L3 Implementations
L2 and L3 Configuration Task Overview
L2 Based Configuration Example Using PVRST Protocol
L2 PVRST Configuration Task Overview
Configuring a Basic L2 PVRST Based Topology
Configure Switch ToR72p-1 for L2 PVRST
Configure Switch ToR72p-2 for L2 PVRST
Configure Switch ES1-24p-1 for L2 PVRST
Configure Switch ES1-24p-2 for L2 PVRST
Verify the L2 PVRST Configuration
Configuring an L2 PVRST Based Topology With Active/Standby Bond on the Servers
Prepare Switch ToR72p-1 for L2 PVRST Active/Standby on the Servers
Prepare Switch ToR72p-2 for L2 PVRST Active/Standby on the Servers
Configure Switch ES1-24p-1 for L2 PVRST Active/Standby on the Servers
Configure Switch ES1-24p-2 for L2 PVRST Active/Standby on the Servers
Verify the L2 PVRST Active/Standby Configuration on the Servers
Configuring an L2 PVRST and LLA Based Topology With Active/Active Bond on the Servers
Configure Switch ES1-24p-1 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ES1-24p-2 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ToR72p-1 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ToR72p-2 for L2 PVRST LLA Active/Active on the Servers
Verify the L2 PVRST LLA Active/Active Configuration on the Servers
L3 RIP and OSPF Configuration Overview
L3 RIP and OSPF Configuration Task Overview
Configuring L3 Routing Based Topology Using RIP
Configure Switch TOR72p-1 for L3 Routing Using RIP
Configure Switch TOR72p-2 for L3 Routing Using RIP
Configure Switch ES1-24p-1 for L3 Routing Using RIP
Verify the L3 RIP Configuration
Configuring L3 Routing Based Topology Using OSPF
Configure Switch TOR72p-1 for L3 Routing Using OSPF
Configure Switch TOR72p-2 for L3 Routing Using OSPF
Configure Switch ES1-24p-1 for L3 Routing Using OSPF
Configure Switch ES1-24p-2 for L3 Routing Using OSPF
ES1-24p-2 SEFOS# configure terminal ES1-24p-2 SEFOS(config)# set gvrp disable ES1-24p-2 SEFOS(config)# set gmrp disable ES1-24p-2 SEFOS(config)# set port-channel enable ES1-24p-2 SEFOS(config)# interface vlan 1 ES1-24p-2 SEFOS(config-if)# shutdown ES1-24p-2 SEFOS(config-if)# no ip address ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# interface range extreme-ethernet 0/1-24 ES1-24p-2 SEFOS(config-if-range)# shutdown ES1-24p-2 SEFOS(config-if-range)# end
See L2 and L3 Topology.
ES1-24p-2 SEFOS# configure terminal ES1-24p-2 SEFOS(config)# interface port-channel 14 ES1-24p-2 SEFOS(config-if)# no shutdown ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# interface port-channel 15 ES1-24p-2 SEFOS(config-if)# no shutdown ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# end
You must add at least one port to the VLAN before you can assign the VLAN a name.
Note - You can add VLANs as tagged or untagged to a port or a port-channel in three different ways. See Adding VLANs.
ES1-24p-2 SEFOS# configure terminal ES1-24p-2 SEFOS(config)# vlan 2005 ES1-24p-2 SEFOS(config-vlan)# ports add port-channel 14 untagged port-channel 14 name 192_168_205_0_RIP_P2P ES1-24p-2 SEFOS(config-vlan)# vlan active ES1-24p-2 SEFOS(config-vlan)# exit ES1-24p-2 SEFOS(config)# vlan 2006 ES1-24p-2 SEFOS(config-vlan)# ports add port-channel 15 untagged port channel 15 name 192_168_206_0_RIP_P2P ES1-24p-2 SEFOS(config-vlan)# vlan active ES1-24p-2 SEFOS(config-vlan)# exit ES1-24p-2 SEFOS(config)# vlan 60 ES1-24p-2 SEFOS(config-vlan)# ports add extreme-ethernet 0/1 untagged extreme-ethernet 0/1 name 192_168_60_0_HOST_P2P ES1-24p-2 SEFOS(config-vlan)# vlan active ES1-24p-2 SEFOS(config-vlan)# exit ES1-24p-2 SEFOS(config)# end
Also, disable spanning-tree on all uplinks.
ES1-24p-2 SEFOS# configure terminal ES1-24p-2 SEFOS(config)# interface port-channel 14 ES1-24p-2 SEFOS(config-if)# switchport pvid 2005 ES1-24p-2 SEFOS(config-if)# spanning-tree disable ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# interface port-channel 15 ES1-24p-2 SEFOS(config-if)# switchport pvid 2006 ES1-24p-2 SEFOS(config-if)# spanning-tree disable ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# end
Configure the host port as an access link with a different VLAN.
ES1-24p-2 SEFOS# configure terminal ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/1 ES1-24p-2 SEFOS(config-if)# description "connected to eth1 nsn172-76" ES1-24p-2 SEFOS(config-if)# switchport pvid 60 ES1-24p-2 SEFOS(config-if)# no shutdown ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/23 ES1-24p-2 SEFOS(config-if)# description "connected to ToR72p-1 on port68" ES1-24p-2 SEFOS(config-if)# channel-group 14 mode active ES1-24p-2 SEFOS(config-if)# no shutdown ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/21 ES1-24p-2 SEFOS(config-if)# description "connected to ToR72p-1 on port72" ES1-24p-2 SEFOS(config-if)# channel-group 14 mode active ES1-24p-2 SEFOS(config-if)# no shutdown ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/24 ES1-24p-2 SEFOS(config-if)# description "connected to ToR72p-2 on port67" ES1-24p-2 SEFOS(config-if)# channel-group 15 mode active ES1-24p-2 SEFOS(config-if)# no shutdown ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/22 ES1-24p-2 SEFOS(config-if)# description "connected to ToR72p-2 on port72" ES1-24p-2 SEFOS(config-if)# channel-group 15 mode active ES1-24p-2 SEFOS(config-if)# no shutdown ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# end
ES1-24p-2 SEFOS# configure terminal ES1-24p-2 SEFOS(config)# interface vlan 2005 ES1-24p-2 SEFOS(config-if)# ip address 192.168.205.20 255.255.255.0 ES1-24p-2 SEFOS(config-if)# no shutdown ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# interface vlan 2006 ES1-24p-2 SEFOS(config-if)# ip address 192.168.206.20 255.255.255.0 ES1-24p-2 SEFOS(config-if)# no shutdown ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# interface vlan 60 ES1-24p-2 SEFOS(config-if)# ip address 192.168.60.10 255.255.255.0 ES1-24p-2 SEFOS(config-if)# no shutdown ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# end
ES1-24p-2 SEFOS# configure terminal ES1-24p-2 SEFOS(config)# router rip ES1-24p-2 SEFOS(config-router)# version 2 ES1-24p-2 SEFOS(config-router)# auto-summary disable ES1-24p-2 SEFOS(config-router)# redistribute connected ES1-24p-2 SEFOS(config-router)# network 192.168.205.20 ES1-24p-2 SEFOS(config-router)# network 192.168.206.20 ES1-24p-2 SEFOS(config-router)# network 192.168.60.10 ES1-24p-2 SEFOS(config-router)# end
ES1-24p-2 SEFOS# configure terminal ES1-24p-2 SEFOS(config)# interface vlan 2005 ES1-24p-2 SEFOS(config-if)# ip rip send version 2 ES1-24p-2 SEFOS(config-if)# ip rip receive version 2 ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# interface vlan 2006 ES1-24p-2 SEFOS(config-if)# ip rip send version 2 ES1-24p-2 SEFOS(config-if)# ip rip receive version 2 ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# interface vlan 60 ES1-24p-2 SEFOS(config-if)# ip rip send version 2 ES1-24p-2 SEFOS(config-if)# ip rip receive version 2 ES1-24p-2 SEFOS(config-if)# exit ES1-24p-2 SEFOS(config)# end
ES1-24p-2 SEFOS# copy run start Building configuration ... [OK] ES1-24p-2 SEFOS#
ES1-24p-2 SEFOS# show interface description Interface Status Protocol Description --------- ------ -------- ----------- Ex0/1 up up connected to eth1 nsn172-76 Ex0/2 down down : : Ex0/20 down down Ex0/21 up up connected to ToR72p-1 on port72 Ex0/22 up up connected to ToR72p-2 on port72 Ex0/23 up up connected to ToR72p-1 on port68 Ex0/24 up up connected to ToR72p-2 on port67 po14 up up po15 up up vlan1 down down vlan2005 up up vlan2006 up up vlan60 up up
ES1-24p-2 SEFOS# show ip route Codes: C - connected, S - static, R - rip, B - bgp, O - ospf R 192.168.9.0/24 [3] via 192.168.205.10 R 192.168.20.0/24 [3] via 192.168.205.10 R 192.168.30.0/24 [2] via 192.168.205.10 R 192.168.40.0/24 [4] via 192.168.205.10 R 192.168.50.0/24 [3] via 192.168.205.10 C 192.168.60.0/24 is directly connected, vlan60 R 192.168.100.0/24 [3] via 192.168.205.10 R 192.168.101.0/24 [3] via 192.168.205.10 R 192.168.150.0/24 [3] via 192.168.205.10 R 192.168.151.0/24 [3] via 192.168.205.10 R 192.168.201.0/24 [2] via 192.168.205.10 R 192.168.202.0/24 [3] via 192.168.205.10 R 192.168.203.0/24 [2] via 192.168.205.10 R 192.168.204.0/24 [3] via 192.168.205.10 C 192.168.205.0/24 is directly connected, vlan2005 C 192.168.206.0/24 is directly connected, vlan2006 R 192.168.205.0/24 [2] via 192.168.203.10 R 192.168.206.0/24 [3] via 192.168.203.10 R 45.45.45.0/24 [3] via 192.168.205.10 R 45.45.46.0/24 [3] via 192.168.205.10 R 45.45.47.0/24 [3] via 192.168.205.10 R 45.45.48.0/24 [3] via 192.168.205.10 R 45.45.49.0/24 [3] via 192.168.205.10 R 45.45.50.0/24 [3] via 192.168.205.10 R 45.45.51.0/24 [3] via 192.168.205.10 ...
After IXIA sends 500 routes to the core switch, those routes are learned on this switch.
ES1-24p-2 SEFOS# show ip route summary Route Source Routes connected 3 static 0 rip 513 bgp 0 ospf 0 Total 516
