System Administration Guide, Volume I
SPARC: Disk Slices
On SPARC systems, Solaris defines eight disk slices and assigns to each a conventional use. These slices are numbered 0 through 7. Table 21-2 summarizes the contents of the eight Solaris slices on a SPARC system.
Table 21-2 SPARC: Customary Disk Slices
Slice
File System
Usually Found on Client or Server Systems?
Purpose
0
root
Both
Holds files and directories that make up the operating system.
1
swap
Both
Provides virtual memory, or swap space. Swap space is used when running programs are too large to fit in a computer's memory. The Solaris operating environment then "swaps" programs from memory to the disk and back as needed.
2
both
Refers to the entire disk, by convention. It is defined automatically by Sun's format and the Solaris installation programs. The size of this slice should not be changed.
3
/export
Server only
Holds alternative versions of the operating system. These alternative versions are required by client systems whose architectures differ from that of the server. Clients with the same architecture type as the server obtain executables from the /usr file system, usually slice 6.
4
/export/swap
Server only
Provides virtual memory space for client systems.
5
/opt
Both
Holds application software added to a system. If a slice is not allocated for this file system during installation, the /opt directory is put in slice 0.
6
/usr
Both
Holds operating system commands--also known as executables-- designed to be run by users. This slice also holds documentation, system programs (init and syslogd, for example) and library routines.
7
/home or
/export/home
Both
Holds files created by users.
