System Administration Guide, Volume I
x86: Disk Slices
On x86 systems, disks are divided into fdisk partitions. An fdisk partition is a section of the disk reserved for a particular operating environment, such as Solaris.
Solaris places ten slices, numbered 0-9, on the Solaris fdisk partition on a disk in an x86 system, as shown in Table 21-3.
Table 21-3 x86: Customary Disk Slices
Slice
File System
Usually Found on Client or Server Systems?
Purpose
0
root
Both
Holds the files and directories that make up the operating system.
1
swap
Both
Provides virtual memory, or swap space. Swap space is used when running programs are too large to fit in a computer's memory. The Solaris operating environment then "swaps" programs from memory to the disk and back as needed.
2
Both
Refers to the entire disk, by convention. It is defined automatically by Sun's format utility and the Solaris installation programs. The size of this slice should not be changed.
3
/export
Server only
Holds alternative versions of the operating system. These alternative versions are required by client systems whose architectures differ from that of the server.
4
/export/swap
Server only
Provides virtual memory space for the client systems.
5
/opt
Both
Holds application software added to a system. If a slice is not allocated for this file system during installation, the /opt directory is put in slice 0.
6
/usr
Both
Holds operating system commands--also known as executables--that are run by users. This slice also holds documentation, system programs (init and syslogd, for example) and library routines.
7
/home or /export/home
Both
Holds files created by users.
8
Both
Contains information necessary for Solaris to boot from the hard disk. It resides at the beginning of the Solaris partition (although the slice number itself does not indicate this), and is known as the boot slice.
9
Both
Provides an area reserved for alternate disk blocks. Slice 9 is known as the alternate sector slice.
