The following example shows the messages displayed if file systems are already mounted when you use the mountall command.
# mountall mount: /tmp already mounted nfs mount: mount: /usr/openwin: Device busy nfs mount: mount: /usr/man: Device busy |
The following example mounts all the local systems listed in the /etc/vfstab file.
# mountall -l # mount / on /dev/dsk/c0t3d0s0 read/write/setuid/largefiles on ... /usr on /dev/dsk/c0t3d0s6 read/write/setuid/largefiles on ... /proc on /proc read/write/setuid on Wed May 27 09:11:50 1998 /dev/fd on fd read/write/setuid on Wed May 27 09:11:50 1998 /tmp on swap read/write on Wed May 27 09:11:50 1998 |
The following example mounts all the remote file systems listed in the /etc/vfstab file.
# mountall -r # mount / on /dev/dsk/c0t3d0s0 read/write/setuid/largefiles on ... /usr on /dev/dsk/c0t3d0s6 read/write/setuid/largefiles on ... /proc on /proc read/write/setuid on Mon Jun 8 10:28:31 1998 /dev/fd on fd read/write/setuid on Mon Jun 8 10:28:31 1998 /tmp on swap read/write on Mon Jun 8 10:28:31 1998 /nfs/mars.dist on mars:/usr/dist intr/remote on ... /nfs/mars.mail on mars:/var/mail intr/noac/remote on ... |
