System Administration Guide, Volume I
Example--Checking Packages Installed in a Spool Directory
The following example shows how to check a software package copied to a spool directory (/export/install/packages).
# pkgchk -d /export/install/packages
## checking spooled package <SUNWadmap>
## checking spooled package <SUNWadmfw>
## checking spooled package <SUNWadmc>
## checking spooled package <SUNWsadml>
Note -
The checks made on a spooled package are limited because not all information can be audited until a package is installed.
