In a diskless or AutoClient system client/server setup, you may want to manage software from a central location. Since the server is the place to do this, you would need to use a variation of the pkginfo command. The following example shows the pkginfo -R command to list all packages installed on a diskless client named io. This command is executed from the diskless client's server.
server$ pkginfo -R /export/root/io system SUNWaccr System Accounting, (Root) system SUNWaccu System Accounting, (Usr) system SUNWadmap System & Network Administration Applications system SUNWadmfw System & Network Administration Framework . . . |
