Become superuser on the system where the users' home directories are created and shared.
Create a skeleton directory for each type of user.
# mkdir /shared-directory/skel/user-type |
shared-directory |
The name of a directory that is available to other systems on the network. |
user-type |
The name of a directory to store initialization files for a type of user. |
Copy the default user initialization files into the directories you created for different types of users.
# cp /etc/skel/local.cshrc /shared-directory/skel/user-type/.cshrc # cp /etc/skel/local.login /shared-directory/skel/user-type/.login # cp /etc/skel/local.profile /shared-directory/skel/user-type /.profile |
You can use the ls -a command to list . (dot) files.
Edit the user initialization files for each user type and customize them based on your site's needs.
See "Customizing a User's Work Environment" for a detailed description on the ways to customize the user initialization files.
Set the permissions for the user initialization files.
# chmod 744 /shared-directory/skel/user-type/.* |
The following example customizes the C-shell user initialization file in the /export/skel/enduser directory designated for a particular type of user.
# mkdir /export/skel/enduser # cp /etc/skel/local.cshrc /export/skel/enduser/.cshrc (Edit .cshrc file-see "Example--.cshrc File ") # chmod 744 /export/skel/enduser/.* |
