Verify that the following prerequisites are met. To use Admintool, you must:
Have a bit-mapped display monitor. The Admintool software can be used only on a system with a console that is a bit-mapped screen such as a standard display monitor that comes with a Sun workstation.
Be running an X Window System, such as the OpenWindows environment.
Be a member of the sysadmin group (group 14).
If you want to perform administration tasks on a system with an ASCII terminal as the console, use Solaris commands instead. See useradd(1M) for more information.
Start Admintool.
$ admintool & |
The Users main window is displayed.
This is the Users main window, which enables you to manage user account information.
