To use the File Pane pop-up menu:
Press MENU from within the File Pane.
Depending on whether you have a folder or file selected, all or some of the following options are available from this menu: Select All, Cut, Copy, Link, Paste, Delete, Print One, Print, Cleanup (Selection). For information on Cut, Copy, Paste and Delete refer to "File Menu". For information on Link, refer to "Linking Files". For information on Cleanup Selection, refer to "View Menu".
