To move or copy folders and files using the clipboard, follow these steps:
Select the file or files you want to copy or move.
The icon is selected. If you want to move a group of files or folders, click ADJUST on individual icons to add them to the group. If the icon is already selected, clicking ADJUST deselects it, removing it from the group.
Choose Cut or Copy from the Edit menu.
Use Cut, or Copy to copy a file. The file or files are moved or copied to the clipboard.
If your keyboard has Cut and Copy keys, you can use them, or Meta-x (Cut) and Meta-c (Copy). (On x86 and PowerPC systems, Meta is Control-Alt.)
An instruction message is displayed in the footer, as shown in Figure 2-18.
Open the folder you want to receive the files.
Choose Paste from the Edit menu or the File Pane pop-up menu.
If your keyboard has a Paste key, you can use that. You may also use Meta-v. (On x86 and PowerPC systems, Meta is Control-Alt.)
