OpenWindows User's Guide
Viewing Single Page Images and Multiple Page Documents
If the image you opened is a single page image, the View window resizes to the size of the image (unless the image extends beyond the size of the screen.)
You can now save your image as described in "Saving an Image", print your image as described in "Printing Images", or use the palette with your image as described in "Using the Image Tool Palette".
If your document is a multiple page document, refer to "Viewing Multiple Page Documents".
