To rotate the image with the Rotate tool, first enter the number of degrees to be applied in the text field next to the buttons.
You can type the value, use the abbreviated menu buttons, or use the sliders. Figure 13-10, shows the rotate icon and an image that has been rotated 90 degrees.
