The File menu contains items that you can use to open, save, save as, include and empty the document for your text files. For complete information on opening and saving files, refer to "Opening, Saving, Including and Attaching Files" in Chapter 1, Introduction to the Solaris User Environment.
Use the include file to include an existing file into a new text file.
Use the Include File item of the File menu to display the Text: Include window.
Locate and include your file.
Include your file in the same manner you would open or save a file. For detailed information on choosing a file to open or save, refer to Chapter 1, Introduction to the Solaris User Environment.
Use the Empty Document item of the File menu to clear the contents of the text pane. If you have made editing changes and have not saved them, a Notice is displayed asking you to confirm or cancel the operation.
