The following example shows the audiotest running from the command line with a combination of standard command-line arguments (-vf) and test specific options (-o M,X)
# /opt/SUNWvts/bin/audiotest -vf -p1 -o M,X "Test Options: M,X" "audiotest: Started." "rec_play: read/write 8000 bytes" "Audio music test" "Audio crystal test, rate = 8000 Hz, time = 998289 usecs" "Audio crystal test, rate = 48000 Hz, time = 999974 usecs" "Starting loopback test: internal_codec" "Play Gain = 230, Record Gain = 0" "Sample Rate = 8000 Hz, Freq = 1000 Hz MONO u-law" " snr = 40.59 dB" "Sample Rate = 8000 Hz, Freq = 1000 Hz MONO a-law" " snr = 44.79 dB" "Sample Rate = 8000 Hz, left = 1000 Hz, right = 1000 Hz" "left : snr = 68.25 dB, gain = -4.99 dB" "right : snr = 68.32 dB, gain = -5.07 dB" "audiotest: Stopped successfully."
Refer to "Running a Test From the Command Line (Tutorial)" and to the SunVTS 3.0 Test Reference Manual for more command line details.
