Go to main content
oracle home
Sun Rack II Product Notes
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Sun Rack II 1242 Documentation Library
Late-Breaking Information
Known Issues
Unsupported Feature in Firmware V2.04, V2.03, ...
Updated: July 2018
Document Information
Using This Documentation
Product Documentation Library
Feedback
Raise Leveling Feet Before Moving the Rack
PDU Replacement Procedures
Monitoring the Enhanced PDU (HTML Interface)
Access a Metering Unit on the Network (Original PDU)
Enhanced PDU
Remove and Dispose of the Plastic Bumpers That Are Shipped With the Rack
Use the Finger-Tighten Method on the Leveling Feet
Known Issues
SSH Login With a Bad Password Locks the User out When Logging in to the BUI (18952597)
LCD Display of IP, SUBM, GATW and DNS Does Not Match the CLI When DHCP Is On (19882719)
With HTTPS SSH Using IPv6 Does Not Disconnect Until the SSH Connection Times Out (19916916)
BUI of a PDU Cannot Be Connected When HTTPS Is Enabled and IPv6 Address Is Used (19916968)
Telnet Over IPv6 Is Not Handled by PDU Firmware (19946327)
CLI Accepts an Empty String as a Valid Password (19953830)
Using CLI SNMPv3 Users Can Be Created With Improper Auth/Priv Passwords (20041214)
Using SNMP a User Cannot Set SNMP Access Port and SNMP Traps Port (20056481)
Enhanced PDU II Accepts Invalid Values for NTP Server IP Via BUI (20068586)
Special Characters Suffixed With Number Fields Are Accepted in Net Configuration (20173108)
Unsupported Feature in Firmware V2.04, V2.03, and V2.02
Unsupported Features in Firmware V2.01 and V2.00
Sun Rack II 1042 Does Not Support Three-Phase PDUs
Ordering Optional Components
Latest PDU Firmware Downloads
Sun Rack II PDU Patch Table
Rack Web Site
Language:
English
VPN is not supported in firmware V2.04, V2.03, and V2.02.
Previous
Next
