| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System XVLAN Administration Guide |
Configure External and Internal Ports in a Solitary-Restricted XVLAN
Allowing Regular VLAN on XVLAN Ports
Configure Regular VLAN on an XVLAN Port
Configure Regular VLAN 100 With Ports Used in an XVLAN
In this example, XVLAN 10 is the principal XVLAN. In addition, XVLAN 100 is identified as a group-restricted XVLAN with internal ports 2 and 15 and external port 1. XVLAN 600 is identified as a solitary-restricted XVLAN with internal ports 19 and 20 and external port 1.
SEFOS# conf t SEFOS(config)# set gvrp disable SEFOS(config)#
SEFOS(config)# xvlan 10 SEFOS(config-xvlan)# ports internal extreme-ethernet 0/2,0/15,0/19,0/20 external extreme-ethernet 0/1 name main
SEFOS(config-xvlan)# xvlan 100 group ports internal extreme-ethernet 0/2,0/15 external extreme-ethernet 0/1 name group100
SEFOS(config-xvlan)# xvlan 600 solo ports internal extreme-ethernet 0/19,0/20 external extreme-ethernet 0/1 name solo600 SEFOS(config-xvlan)# exit SEFOS(config)#
SEFOS(config)# internal extreme-ethernet 0/1 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit SEFOS(config)# SEFOS(config)# internal extreme-ethernet 0/2 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit SEFOS(config)# SEFOS(config)# end
SEFOS# show xvlan Exclusive Vlan database --------------------------- XVlan ID : 10 Type : Principal Principal XVlan : 10 External Ports : Ex0/1 Internal Ports : Ex0/2, Ex0/15, Ex0/19, Ex0/20 ISWTrunk Ports : Name : main ---------------------------------------------------- XVlan ID : 100 Type : Restricted: Group Principal XVlan : 10 External Ports : Ex0/1 Internal Ports : Ex0/2, Ex0/15 ISWTrunk Ports : Name : group100 ---------------------------------------------------- XVlan ID : 600 Type : Restricted: Solitary Principal XVlan : 10 External Ports : Ex0/1 Internal Ports : Ex0/19, Ex0/20 ISWTrunk Ports : Name : solo600 ----------------------------------------------------
[root@nsn173-147 ~]# ping 38.38.38.70 PING 38.38.38.70 (38.38.38.70) 56(84) bytes of data. 64 bytes from 38.38.38.70: icmp_seq=0 ttl=64 time=0.193 ms 64 bytes from 38.38.38.70: icmp_seq=1 ttl=64 time=0.269 ms 64 bytes from 38.38.38.70: icmp_seq=2 ttl=64 time=0.099 ms 64 bytes from 38.38.38.70: icmp_seq=3 ttl=64 time=0.146 ms [root@nsn173-147 ~]# ping 38.38.38.146 PING 38.38.38.146 (38.38.38.146) 56(84) bytes of data. 64 bytes from 38.38.38.146: icmp_seq=0 ttl=255 time=0.352 ms 64 bytes from 38.38.38.146: icmp_seq=1 ttl=255 time=0.261 ms 64 bytes from 38.38.38.146: icmp_seq=2 ttl=255 time=0.084 ms
[root@nsn173-147 ~]# ping 38.38.38.64 PING 38.38.38.64 (38.38.38.64) 56(84) bytes of data. From 38.38.38.147 icmp_seq=1 Destination Host Unreachable From 38.38.38.147 icmp_seq=2 Destination Host Unreachable From 38.38.38.147 icmp_seq=3 Destination Host Unreachable From 38.38.38.147 icmp_seq=5 Destination Host Unreachable
