| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System XVLAN Administration Guide |
Configure External and Internal Ports in a Solitary-Restricted XVLAN
Configure Ports in Solitary- and Group-Restricted XVLANs
Allowing Regular VLAN on XVLAN Ports
Configure Regular VLAN on an XVLAN Port
This example assumes the same configuration of SEFOS1 as is described in Single-Switch Configuration. The additional switch that is included in the multiple-switch configuration (SEFOS2) is configured as described in this section.
SEFOS# conf t SEFOS(config)# set gvrp disable SEFOS(config)#
SEFOS(config)# xvlan 10 SEFOS(config-xvlan)# ports internal extreme-ethernet 0/2,0/11-12 external extreme-ethernet 0/1 name main
SEFOS(config-xvlan)# xvlan 100 group ports internal extreme-ethernet 0/2 external extreme-ethernet 0/1 name group100
SEFOS(config-xvlan)# xvlan 600 solo ports internal extreme-ethernet 0/11-12 external extreme-ethernet 0/1 name solo600 SEFOS(config-xvlan)# exit SEFOS(config)#
SEFOS(config)# internal extreme-ethernet 0/1 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit SEFOS(config)# SEFOS(config)# internal extreme-ethernet 0/2 SEFOS(config-if)# no shut SEFOS(config-if)# exit SEFOS(config)# internal extreme-ethernet 0/11-12 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit SEFOS(config)# SEFOS(config)# end
SEFOS# show xvlan Exclusive Vlan database --------------------------- XVlan ID : 10 Type : Principal Principal XVlan : 10 External Ports : Ex0/1 Internal Ports : Ex0/2, Ex0/11, Ex0/12 ISWTrunk Ports : Name : main ---------------------------------------------------- XVlan ID : 100 Type : Restricted: Group Principal XVlan : 10 External Ports : Ex0/1 Internal Ports : Ex0/2 ISWTrunk Ports : Name : group100 ---------------------------------------------------- XVlan ID : 600 Type : Restricted: Solitary Principal XVlan : 10 External Ports : Ex0/1 Internal Ports : Ex0/11, Ex0/12 ISWTrunk Ports : Name : solo600 ----------------------------------------------------
nsn173-90:~ # ping 38.38.38.139 PING 38.38.38.139 (38.38.38.139) 56(84) bytes of data. 64 bytes from 38.38.38.139: icmp_seq=1 ttl=64 time=3.44 ms 64 bytes from 38.38.38.139: icmp_seq=2 ttl=64 time=0.159 ms [root@nsn173-139 ~]# ping 38.38.38.149 PING 38.38.38.149 (38.38.38.149) 56(84) bytes of data. 64 bytes from 38.38.38.149: icmp_seq=1 ttl=255 time=0.318 ms 64 bytes from 38.38.38.149: icmp_seq=2 ttl=255 time=0.126 ms [root@nsn173-139 ~]# ping 38.38.38.66 PING 38.38.38.66 (38.38.38.66) 56(84) bytes of data. 64 bytes from 38.38.38.66: icmp_seq=1 ttl=64 time=1.06 ms 64 bytes from 38.38.38.66: icmp_seq=2 ttl=64 time=0.162 ms 64 bytes from 38.38.38.66: icmp_seq=3 ttl=64 time=0.115 ms [root@nsn173-139 ~]# ping 38.38.38.90 PING 38.38.38.90 (38.38.38.90) 56(84) bytes of data. 64 bytes from 38.38.38.90: icmp_seq=1 ttl=64 time=1.68 ms 64 bytes from 38.38.38.90: icmp_seq=2 ttl=64 time=0.194 ms 64 bytes from 38.38.38.90: icmp_seq=3 ttl=64 time=0.145 ms [root@nsn173-147 ~]# ping 38.38.38.70 PING 38.38.38.70 (38.38.38.70) 56(84) bytes of data. 64 bytes from 38.38.38.70: icmp_seq=0 ttl=64 time=0.193 ms 64 bytes from 38.38.38.70: icmp_seq=1 ttl=64 time=0.269 ms 64 bytes from 38.38.38.70: icmp_seq=2 ttl=64 time=0.099 ms 64 bytes from 38.38.38.70: icmp_seq=3 ttl=64 time=0.146 ms [root@nsn173-147 ~]# ping 38.38.38.146 PING 38.38.38.146 (38.38.38.146) 56(84) bytes of data. 64 bytes from 38.38.38.146: icmp_seq=0 ttl=255 time=0.352 ms 64 bytes from 38.38.38.146: icmp_seq=1 ttl=255 time=0.261 ms 64 bytes from 38.38.38.146: icmp_seq=2 ttl=255 time=0.084 ms
[root@nsn173-147 ~]# ping 38.38.38.64 PING 38.38.38.64 (38.38.38.64) 56(84) bytes of data. From 38.38.38.147 icmp_seq=1 Destination Host Unreachable From 38.38.38.147 icmp_seq=2 Destination Host Unreachable From 38.38.38.147 icmp_seq=3 Destination Host Unreachable From 38.38.38.147 icmp_seq=5 Destination Host Unreachable
nsn173-90:~ # ping 38.38.38.149 PING 38.38.38.149 (38.38.38.149) 56(84) bytes of data. ^C --- 38.38.38.149 ping statistics --- 2 packets transmitted, 0 received, 100% packet loss, time 999ms nsn173-90:~ # ping 38.38.38.66 PING 38.38.38.66 (38.38.38.66) 56(84) bytes of data. ^C --- 38.38.38.66 ping statistics --- 2 packets transmitted, 0 received, 100% packet loss, time 1013ms
