Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System XVLAN Administration Guide |
Configure External and Internal Ports in a Solitary-Restricted XVLAN
Configure Ports in Solitary- and Group-Restricted XVLANs
Allowing Regular VLAN on XVLAN Ports
Configure Regular VLAN on an XVLAN Port
The interconnect between the two switches can be a regular port or an 802.3ad link aggregation port. In this example, a LAG port is used.
This task shows how to create a LAG port between the two NEMs and assign it as inter-switch trunk port.
SEFOS# conf t SEFOS(config)# set port-channel enable SEFOS(config)# SEFOS(config)# internal port-channel 36 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit SEFOS(config)# SEFOS(config)# internal range extreme-ethernet 0/3-6 SEFOS(config-if-range)# shutdown SEFOS(config-if-range)# channel-group 36 mode active SEFOS(config-if-range)# no shutdown SEFOS(config-if-range)# exit SEFOS(config)# SEFOS(config)# xvlan 10 SEFOS(config-xvlan)# port add inter-switch po 36 SEFOS(config-xvlan)# xvlan 600 solo port add inter-switch po 36 SEFOS(config-xvlan)# xvlan 100 group port add inter-switch po 36 SEFOS(config-xvlan)# SEFOS(config-xvlan)# end
SEFOS# show xvlan Exclusive Vlan database --------------------------- XVlan ID : 10 Type : Principal Principal XVlan : 10 External Ports : Ex0/1 Internal Ports : Ex0/2, Ex0/15, Ex0/19, Ex0/20 ISWTrunk Ports : po36 Name : main ---------------------------------------------------- XVlan ID : 100 Type : Restricted: Group Principal XVlan : 10 External Ports : Ex0/1 Internal Ports : Ex0/2, Ex0/15 ISWTrunk Ports : po36 Name : group100 ---------------------------------------------------- XVlan ID : 600 Type : Restricted: Solitary Principal XVlan : 10 External Ports : Ex0/1 Internal Ports : Ex0/19, Ex0/20 ISWTrunk Ports : po36 Name : solo600 ----------------------------------------------------
SEFOS# conf t SEFOS(config)# set port-channel enable SEFOS(config)# SEFOS(config)# internal port-channel 36 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit SEFOS(config)# SEFOS(config)# internal range extreme-ethernet 0/3-6 SEFOS(config-if-range)# shutdown SEFOS(config-if-range)# channel-group 36 mode active SEFOS(config-if-range)# no shutdown SEFOS(config-if-range)# exit SEFOS(config)# SEFOS(config)# xvlan 10 SEFOS(config-xvlan)# port add inter-switch po 36 SEFOS(config-xvlan)# xvlan 600 solo port add inter-switch po 36 SEFOS(config-xvlan)# xvlan 100 group port add inter-switch po 36 SEFOS(config-xvlan)# exit SEFOS(config)# end SEFOS#
SEFOS# show xvlan Exclusive Vlan database --------------------------- XVlan ID : 10 Type : Principal Principal XVlan : 10 External Ports : Ex0/1 Internal Ports : Ex0/2, Ex0/11, Ex0/12 ISWTrunk Ports : po36 Name : main ---------------------------------------------------- XVlan ID : 100 Type : Restricted: Group Principal XVlan : 10 External Ports : Ex0/1 Internal Ports : Ex0/2 ISWTrunk Ports : po36 Name : group100 ---------------------------------------------------- XVlan ID : 600 Type : Restricted: Solitary Principal XVlan : 10 External Ports : Ex0/1 Internal Ports : Ex0/11, Ex0/12 ISWTrunk Ports : po36 Name : solo600 ----------------------------------------------------
SEFOS# show etherchannel summary Port-channel Module Admin Status is enabled Port-channel Module Oper Status is enabled Port-channel System Identifier is 00:14:4f:6c:56:0f Flags: D - down P - in port-channel I - stand-alone H - Hot-standby (LACP only) Number of channel-groups in use: 1 Number of aggregators: 1 Group Port-channel Protocol Ports ------------------------------------------------------------------------- 36 Po36(P) LACPEx0/3(P),Ex0/4(P),Ex0/5(P),Ex0/6(P)
[root@nsn173-139 ~]# ping 38.38.38.146 PING 38.38.38.146 (38.38.38.146) 56(84) bytes of data. 64 bytes from 38.38.38.146: icmp_seq=1 ttl=255 time=1.71 ms 64 bytes from 38.38.38.146: icmp_seq=2 ttl=255 time=0.054 ms 64 bytes from 38.38.38.146: icmp_seq=3 ttl=255 time=0.135 ms
[root@nsn173-139 ~]# ping 38.38.38.147 PING 38.38.38.147 (38.38.38.147) 56(84) bytes of data. 64 bytes from 38.38.38.147: icmp_seq=1 ttl=64 time=0.793 ms 64 bytes from 38.38.38.147: icmp_seq=2 ttl=64 time=0.236 ms 64 bytes from 38.38.38.147: icmp_seq=3 ttl=64 time=0.334 ms [root@nsn173-139 ~]# ping 38.38.38.70 PING 38.38.38.70 (38.38.38.70) 56(84) bytes of data. 64 bytes from 38.38.38.70: icmp_seq=1 ttl=64 time=2.04 ms 64 bytes from 38.38.38.70: icmp_seq=2 ttl=64 time=0.085 ms 64 bytes from 38.38.38.70: icmp_seq=3 ttl=64 time=0.166 ms [root@nsn173-139 ~]# ping 38.38.38.64 PING 38.38.38.64 (38.38.38.64) 56(84) bytes of data. 64 bytes from 38.38.38.64: icmp_seq=1 ttl=64 time=1.70 ms 64 bytes from 38.38.38.64: icmp_seq=2 ttl=64 time=0.238 ms [root@nsn173-139 ~]# ping 38.38.38.65 PING 38.38.38.65 (38.38.38.65) 56(84) bytes of data. 64 bytes from 38.38.38.65: icmp_seq=1 ttl=64 time=1.29 ms 64 bytes from 38.38.38.65: icmp_seq=2 ttl=64 time=0.192 ms
nsn173-90:~ # ping 38.38.38.139 PING 38.38.38.139 (38.38.38.139) 56(84) bytes of data. 64 bytes from 38.38.38.139: icmp_seq=1 ttl=64 time=1.94 ms
The hosts are expected to be unreachable.
nsn173-90:~ # ping 38.38.38.147 PING 38.38.38.147 (38.38.38.147) 56(84) bytes of data. From 38.38.38.90: icmp_seq=1 Destination Host Unreachable From 38.38.38.90 icmp_seq=1 Destination Host Unreachable From 38.38.38.90 icmp_seq=2 Destination Host Unreachable nsn173-90:~ # ping 38.38.38.64 PING 38.38.38.64 (38.38.38.64) 56(84) bytes of data. From 38.38.38.90: icmp_seq=2 Destination Host Unreachable From 38.38.38.90 icmp_seq=2 Destination Host Unreachable From 38.38.38.90 icmp_seq=3 Destination Host Unreachable nsn173-90:~ # ping 38.38.38.65 PING 38.38.38.65 (38.38.38.65) 56(84) bytes of data. From 38.38.38.90: icmp_seq=1 Destination Host Unreachable From 38.38.38.90 icmp_seq=1 Destination Host Unreachable From 38.38.38.90 icmp_seq=2 Destination Host Unreachable nsn173-90:~ # ping 38.38.38.70 PING 38.38.38.70 (38.38.38.70) 56(84) bytes of data. From 38.38.38.90: icmp_seq=1 Destination Host Unreachable From 38.38.38.90 icmp_seq=1 Destination Host Unreachable From 38.38.38.90 icmp_seq=2 Destination Host Unreachable
The hosts are expected to be reachable. On the restricted XVLAN 100, the following hosts are assigned:
On SEFOS1, port 2 is assigned host .147, port 15 is assigned host .70.
On SEFOS2, port 2 is assigned host .149.
# ping 38.38.38.70 38.38.38.70 is alive # ping 38.38.38.147 38.38.38.147 is alive #
SEFOS# show mac-address-table Vlan Mac Address Type Ports ---- ----------- ---- ----- 10 00:00:5a:9f:71:a8 Learnt Ex0/2 10 00:14:4f:1e:da:21 Learnt Ex0/1 10 00:14:4f:1e:e1:8f Learnt po36 10 00:14:4f:6c:63:11 Learnt po36 10 00:14:4f:6c:63:12 Learnt po36 10 00:14:4f:6c:63:13 Learnt po36 10 00:14:4f:6c:63:14 Learnt po36 10 00:14:4f:6c:63:27 Learnt po36 10 00:14:4f:6c:78:e8 Learnt po36 10 00:1b:21:51:26:bd Learnt po36 10 00:1b:21:51:26:ed Learnt po36 10 00:1b:21:53:6d:b9 Learnt Ex0/19 10 00:1b:21:53:6e:55 Learnt Ex0/15 10 00:1b:21:66:4a:a1 Learnt Ex0/20
SEFOS# show mac-address-table Vlan Mac Address Type Ports ---- ----------- ---- ----- 10 00:00:5a:9f:71:a8 Learnt po36 10 00:14:4f:1e:da:21 Learnt po36 10 00:14:4f:1e:e1:8f Learnt Ex0/2 10 00:14:4f:6c:56:11 Learnt po36 10 00:14:4f:6c:56:12 Learnt po36 10 00:14:4f:6c:56:13 Learnt po36 10 00:14:4f:6c:56:14 Learnt po36 10 00:14:4f:6c:56:27 Learnt po36 10 00:14:4f:6c:78:e8 Learnt Ex0/1 10 00:1b:21:51:26:bd Learnt Ex0/12 10 00:1b:21:51:26:ed Learnt Ex0/11 10 00:1b:21:53:6e:55 Learnt po36 Total Mac Addresses displayed: 12
