| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System XVLAN Administration Guide |
Configure External and Internal Ports in a Solitary-Restricted XVLAN
Configure Ports in Solitary- and Group-Restricted XVLANs
Allowing Regular VLAN on XVLAN Ports
Configure Regular VLAN on an XVLAN Port
Configure Regular VLAN 100 With Ports Used in an XVLAN
SEFOS# show vlan port config Vlan Port configuration table ------------------------------- ?... Port Ex0/3 Port Vlan ID : 10 Port Acceptable Frame Type : Admit All Port Ingress Filtering : Disabled Port Mode : Hybrid Exclusive VLAN Port Mode : External VLAN & Exclusive VLAN Port Sharing : Disabled Exclusive VLAN VID : 10 Port Gvrp Status : Enabled Port Gmrp Status : Enabled Port Gvrp Failed Registrations : 0 Gvrp last pdu origin : 00:00:00:00:00:00 Port Restricted Vlan Registration : Disabled Port Restricted Group Registration : Disabled Mac Based Support : Disabled Subnet Based Support : Disabled Port-and-Protocol Based Support : Enabled Default Priority : 0 Tunnel Status : Disabled Dot1x Protocol Tunnel Status : Peer LACP Protocol Tunnel Status : Peer Spanning Tree Tunnel Status : Peer GVRP Protocol Tunnel Status : Peer GMRP Protocol Tunnel Status : Peer IGMP Protocol Tunnel Status : Peer Filtering Utility Criteria : Default Port Protected Status : Disabled ------------------------------------------------------- ?... Port Ex0/15 Port Vlan ID : 30 Port Acceptable Frame Type : Admit All Port Ingress Filtering : Disabled Port Mode : Hybrid Exclusive VLAN Port Mode : Internal VLAN & Exclusive VLAN Port Sharing : Disabled Exclusive VLAN VID : 30 Port Gvrp Status : Enabled Port Gmrp Status : Enabled Port Gvrp Failed Registrations : 0 Gvrp last pdu origin : 00:00:00:00:00:00 Port Restricted Vlan Registration : Disabled Port Restricted Group Registration : Disabled Mac Based Support : Disabled Subnet Based Support : Disabled Port-and-Protocol Based Support : Enabled Default Priority : 0 Tunnel Status : Disabled Dot1x Protocol Tunnel Status : Peer LACP Protocol Tunnel Status : Peer Spanning Tree Tunnel Status : Peer GVRP Protocol Tunnel Status : Peer GMRP Protocol Tunnel Status : Peer IGMP Protocol Tunnel Status : Peer Filtering Utility Criteria : Default Port Protected Status : Disabled
