| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS REM HBA Installation Guide For HBA Models SGX-SAS6-REM-Z and SG-SAS6-REM-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Chapter 4 HBA Software Installation
You can toggle between the two volumes by pressing Alt+N.
The volume is now activated, and can be used by the HBA.
