| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS REM HBA Installation Guide For HBA Models SGX-SAS6-REM-Z and SG-SAS6-REM-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Chapter 4 HBA Software Installation
When you connect a RAID volume to the HBA, and that volume was created outside of the HBA or was previously connected to a different HBA, the HBA considers this volume to be a foreign RAID volume. To protect data, the foreign RAID volume is unusable by the operating system or system boot loader until you manually activate it. You must manually activate a volume in the following situations:
You need to move the physical disks that make up a hardware RAID volume from one system to another system with the HBA.
You need to replace an existing HBA that is managing hardware RAID volumes with a new HBA.
