sunHwTrapComponentFault |
fault.memory.intel.boot-setup-init-failed |
Major; A component
is suspected of causing a fault |
/SYS/ |
fault.memory.intel.boot-retries-failed |
fault.memory.intel.dimm.none |
/SYS/MB |
fault.memory.controller.input-invalid |
fault.memory.controller.init-failed |
sunHwTrapComponentFault Cleared |
Informational; A component fault has been cleared |
/SYS/ |
/SYS/MB |
fault.chassis.device.misconfig |
Major; A component
/SYS/SP |
fault.sp.failed |
sunHwTrapComponentFaultCleared |
fault.sp.failed |
fault.chassis.env.temp.over-fail |
Major; A component
/SYS/ |
/SYS/ |
sunHwTrapTempCritThresholdExceeded |
Lower critical threshold
exceeded |
Major; A temperature sensor has reported that its value has gone above an
upper critical threshold setting or below a lower critical threshold setting |
/SYS/MB/T_OUT /SYS/DBP/T_AMB |
Upper critical threshold
exceeded |
/SYS/MB/T_OUT /SYS/T_AMB /SYS/DBP/T_AMB |
sunHwTrapTempCritThresholdDeasserted |
Lower critical threshold no longer exceeded |
Informational; A temperature sensor has reported that its
value is in the normal operating range |
Upper critical threshold no longer exceeded |
sunHwTrapTempNonCritThresholdExceeded |
Upper
noncritical threshold exceeded |
Minor; A temperature sensor has reported that its value has gone
above an upper critical threshold setting or below a lower critical threshold setting |
sunHwTrapTempOk |
Upper
noncritical threshold no longer exceeded |
Informational; A temperature sensor has reported that its value is
sunHwTrapTempFatalThresholdExceeded |
Lower fatal threshold exceeded |
Critical; A temperature sensor has reported
that its value has gone above an upper fatal threshold setting or below
a lower fatal threshold setting |
Upper fatal threshold exceeded |
sunHwTrapTempFatalThresholdDeasserted |
Lower fatal threshold no longer
exceeded |
Informational; A temperature sensor has reported that its value has gone below an
upper fatal threshold setting or above a lower fatal threshold setting |
fault.chassis.power.missing |
Major; A component is suspected of causing a fault |
/SYS/ |
fault.chassis.power.overcurrent |
fault.chassis.power.inadequate |
has been cleared |
/SYS/ |
sunHwTrapPowerSupplyFault |
fault.chassis.env.power.loss |
Major; A power supply component is suspected of causing a fault |
/SYS/PS |
fault.chassis.power.ac-low-line |
fault.chassis.device.wrong |
sunHwTrapPowerSupplyFaultCleared |
Informational;
A power supply component fault has been cleared |
/SYS/PS |
sunHwTrapPowerSupplyError |
Assert |
Major; A power supply sensor has detected
an error |
/SYS/PWRBS /SYS/PSn/ V_IN_ERR /SYS/PSn/ V_IN_WARN /SYS/PSn/ V_OUT_ERR /SYS/PSn/ I_OUT_ERR /SYS/PSn/ I_OUT_WARN /SYS/PSn/T_ERR /SYS/PSn/ T_WARN /SYS/PSn/ FAN_ERR /SYS/PSn/ FAN_WARN /SYS/PSn/ERR |
Deassert |
/SYS/PSn/ V_OUT_OK |
sunHwTrapPowerSupplyOk |
Deassert |
Informational; A power supply sensor has returned to its normal state |
Assert |
sunHwTrapComponentError |
ACPI_ON_WORKING ASSERT |
Major;
A sensor has detected an error |
/SYS/ACPI |
ACPI_ON_WORKING DEASSERT |
ACPI_SOFT_OFF ASSERT |
ACPI_SOFT_OFF DEASSERT |
UNKNOWN |
ENTITY_PRESENT ASSERT |
Informational |
/SYS/MB/P n/ PRSNT /SYS/MB/Pn/MRn/PRSNT /SYS/MB/PCIEn/PRSNT /SYS/MB/ PCIE_CC/PRSNT |
ENTITY_PRESENT DEASSERT |
ENTITY_ABSENT ASSERT |
ENTITY_ABSENT DEASSERT |
ENTITY_DISABLED
ASSERT |
ENTITY_DISABLED DEASSERT |
Fans, Hard Drives, and Physical Security Events |
fault.chassis.device.fan.column-fail |
/SYS |
fault.security.enclosure-open |
been cleared |
/SYS/ |
UNKNOWN |
Assert |
Informational |
/SYS/MB/PCIE n/WIDTH /SYS/ESMR/ESM/FAULT |
Deassert |
sunHwTrapSecurityIntrusion |
CHASSIS_INTRUSION ASSERT |
Major; An intrusion sensor has detected that someone may have physically
tampered with the system |
/SYS/INTSW |
CHASSIS_INTRUSION DEASSERT |
sunHwTrapFanSpeedCritThresholdExceeded |
Lower critical threshold exceeded |
Major; A fan speed sensor
has reported that its value has gone above an upper critical threshold setting
/SYS/FB/FANn/ TACH |
sunHwTrapFanSpeedCritThresholdDeasserted |
Informational; A
fan speed sensor has reported that its value has gone below an upper
critical threshold setting or above a lower critical threshold setting |
sunHwTrapFanSpeedFatalThresholdExceeded |
Critical;
A fan speed sensor has reported that its value has gone above an
upper fatal threshold setting or below a lower fatal threshold setting |
sunHwTrapFanSpeedFatalThresholdDeasserted |
Informational; A fan speed sensor has reported that its value has
gone below an upper fatal threshold setting or above a lower fatal threshold
setting |
System Chassis and I/O Events |
fault.chassis.boot.ipmi-init-failed |
/SYS/ |
fault.io.quickpath.qpirc-init-failed |
fault.io.quickpath.qpirc-failed |
fault.io.quickpath.mrc-failed |
cleared |
/SYS/ |
