| Skip Navigation Links | |
| Exit Print View | |
Sun Server X2-4 (formerly Sun Fire X4470 M2) Installation Guide for VMware ESXi |
VMware ESXi Installation Task Map
Supported VMware ESXi Software
Selecting the Console Display Option
Selecting the Boot Media Option
Boot Media Options Requirements
Set Up the Local Boot Media Option
Set Up the Remote Boot Media Option
Selecting the Installation Target Option
Set Up a Local Storage Drive (HDD or SSD) as the Installation Target
Set Up a Fibre Channel Storage Area Network Device as the Installation Target
VMware ESXi Installation Options
Single-Server Installation Methods
2. Preparing to Install VMware ESXi
Verify the BIOS Factory Defaults
Installing VMware ESXi on a Single System Using Media
Install VMware ESXi Using Local or Remote Media
4. Post Installation Tasks for VMware ESXi
Configuring Network Adapter Settings
Configure Network Adapter Settings
Determining the MAC Address of a Connected Server Network Port
Determine the MAC Address of a Connected Server Network Port
Updating the VMware ESXi Software
5. Configuring Network Interfaces
6. Getting Server Firmware and Software
Firmware and Software Access Options
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Gathering Information for the Physical Media Request
The server has four network ports, NET0, NET1, NET2, and NET3. When any of these ports are connected to the network, VMware ESXi assigns a MAC address to the port. The following procedure describes how to use the Oracle ILOM command-line interface (CLI) to determine the MAC address assigned by VMware ESXi.
-> show /System/Networking/Ethernet_NICs/Ethernet_NIC_n
Where n is 0, 1, 2, or 3
For example, if server network port NET0 is connected, then the above CLI command produces the following output, where the mac_addresses field lists the MAC address.
-> show /System/Networking/Ethernet_NICs/Ethernet_NIC_0
Targets:
Properties:
health = OK
health_details = -
location = NET0 (Ethernet NIC 0)
manufacturer = INTEL
part_number = X540
serial_number = Not Available
mac_addresses = 00:21:28:3D:B7:96
Commands:
cd
show
Note - If you are unsure of which network adapter to select, contact your network administrator.
