oracle home
Netra SPARC T4-1 Server Product Notes
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Netra SPARC T4-1 Server Documentation Library
Late-Breaking Information
General Notes
Updated: April 2015
Document Information
Using This Documentation
Product Documentation Library
Feedback
Chapter 1 Late-Breaking Information
General Notes
16 GB Dual-Rank DIMMs and System Firmware
Preinstalled Software
Supported Oracle Solaris OS and Firmware Information
OS Package and Patch Updates
Oracle Solaris 11 OS Package Updates
Patch Updates for Oracle Solaris 10 8/11
Downloading Patches and Software Updates
Download Patches
Download Software Updates
PCIe Card Installation Rules
Slot Restrictions for Certain Cards
PCIe Card Cable Restrictions
Chapter 2 Known Product Issues
Hardware Issues
Oracle ILOM Remote Console Video Redirection Not Supported
Direct I/O Support
Downloading sas2ircu Documentation for SPARC T4 Servers
Sun Type 6 Keyboards Are Not Supported by SPARC T4 Series Servers
SPARC T3 and T4 Platforms Might See Dropped or Doubled Character Input From USB Keyboards (Bug ID 15700526, Bug ID 15728507, CR 7067025)
Supplementary Notes
L2 Cache UEs Are Sometimes Reported as Core Faults Without Any Cache Line Retirements (Bug ID 15731176, CR 7071237)
Upon a Reboot After an Unrecoverable Hardware Error, CPUs Might Not Start (Bug ID 15733431, CR 7075336)
Oracle Solaris OS Issues
Spurious Error Message During Initial Oracle Solaris OS Installation (Bug ID 15658412, CR 6971896)
When diag-switch? Is Set to true, Oracle Solaris OS Fails to Update EEPROM for Automatic Rebooting (Bug ID 15666767, CR 6982060)
The cfgadm Command Fails for Certain HBAs (Bug ID 15715604, CR 7044759)
Firmware Issues
e1000g Driver Generates Spurious ereports When Installing Oracle Solaris OS Over a Sun PCIe Dual Gigabit Ethernet Adapter (Bug ID 15647420, CR 6958011)
Units Used to Define the MIB Power Management Time Limit Are Reported in Seconds (Bug ID 15675720, CR 6993008)
Blue OK-to-Remove LED on Drive Does Not Light When the Drive Is Ready to Remove (Bug ID 15737491, CR 7082700)
Timestamp for an Oracle ILOM Fault/Critical Event Might Be Off by One Hour (Bug ID 15802097, CR 6943957)
reboot disk Command Occasionally Fails When disk Argument Picks Up Extra Characters (Bug ID 15816272, CR 7050975)
Language:
English
General Notes
This section contains general notes related to the current release of the server.
Previous
Next
