When you attempt to unconfigure a drive for removal, the drive's blue LED that indicates the drive is ready for removal might not light. This situation happens after you place a drive in a slot in place of a drive that had a different WWN.
Workaround: If you inserted a drive after booting the server, realize that the blue LED will not perform this function until the server has booted again.
