Go to main content
Sun Storage 16 Gb Fibre Channel PCIe Host Bus Adapter, Emulex Installation Guide For HBA Model 7101684
Exit Print View
Updated: August 2018
Utilities for Upgrading the BIOS and Firmware
Use the OneCommand Manager command-line interface (CLI) or the OneCommand Manager graphical user interface (GUI) to update the BIOS and firmware for the HBA. These utilities provide support for the following functions:
  • Discover local and remote hosts, HBAs, targets, and LUNs.
  • Reset HBAs.
  • Set HBA driver parameters.
  • Update firmware.
  • Enable or disable the system BIOS.
  • Run diagnostic tests on HBAs.
  • Manage out-of-band HBAs.
  • Manage local and in-band remote HBAs.
For more information about the HBAnyware and OneCommandManager utilities, download their user manuals from the Emulex (Broadcom) support site for Oracle at: https://www.broadcom.com/support/oem/oracle-fc/.
