The HBA is shipped with two mounting brackets: a pre-installed, low-profile PCIe mounting bracket, and a standard bracket, included in the box with the HBA. The low-profile mounting bracket is shorter than the standard bracket; approximately 3.11 in. (7.9 cm) compared to 4.75 in. (12.06 cm). If you need to change the bracket to install the HBA, you must first remove the optical transceivers from their housing. See To Replace the Low-Profile Bracket With a Standard Bracket. This procedure covers how to install the HBA with the low-profile mounting bracket installed.
Determine an appropriate PCIe slot in which to install the HBA.
Power down the system.
Disconnect power from the system.
Remove the necessary covers and bezels from the system.
For detailed instructions on how to perform these actions, refer to your system documentation.
Replace the necessary covers and bezels onto the system.
Reinstall the server chassis in the rack.
The HBA is now installed and ready for optical or copper cable attachment.
