Document Information
Using This Documentation
Related Documentation
Documentation Feedback
Product Downloads
Download Product Software and Firmware
Oracle ILOM 3.1 Firmware Version Numbering Scheme
Support and Accessibility
Quick Start
Oracle ILOM 3.1 – Quick Start
Factory Default Settings
Mandatory Setup Tasks
Optional Setup Tasks
Daily Management Tasks
Routine Maintenance Tasks
Initial Setup FAQs
Configuration and Maintenance
Setting Up a Management Connection to Oracle ILOM and Logging In
Establishing a Management Connection to Oracle ILOM
Logging In to Oracle ILOM Server SP or CMM
Configuring Oracle ILOM for Maximum Security
Setting Up and Maintaining User Accounts
Managing User Credentials
Configuring Local User Accounts
Configuring Active Directory
Configuring LDAP/SSL
Configuring LDAP
Configuring RADIUS
Modifying Default Settings for Network Deployment and Administration
Network Deployment Principles and Considerations
Modifying Default Management Access Configuration Properties
Modifying Default Connectivity Configuration Properties
Example Setup of Dynamic DNS
Assigning System Identification Information
Setting Properties for SP or CMM Clock
Suggested Resolutions for Network Connectivity Issues
Using Remote KVMS Consoles for Host Server Redirection
First-Time Setup for Oracle ILOM Remote Console
Launching and Using the Oracle ILOM Remote Console
First Time Setup for Oracle ILOM Storage Redirection CLI
Launching and Using the Oracle ILOM Storage Redirection CLI
Starting and Stopping a Host Serial Redirection Session
Host Serial Console Log Properties
Configuring Host Server Management Actions
Controlling Host Power to Server or Blade System Chassis
Setting Host Diagnostic Tests to Run
Setting Next Boot Device on x86 Host Server
Setting Boot Behavior on SPARC Host Server
Overriding SPARC Host Boot Mode
Managing SPARC Host Domains
Setting SPARC Host KeySwitch State
Setting SPARC Host TPM State
Setting Up Alert Notifications and Syslog Server for Event Logging
Configuring Alert Notifications
Configuring Syslog for Event Logging
Setting System Management Power Source Policies
Power-On and Cooling-Down Policies Configurable From the Server SP
System Management Power Supply Policies Configurable From CMM
Setting Power Alert Notifications and Managing System Power Usage
Setting Power Consumption Alert Notifications
Setting CMM Power Grant and SP Power Limit Properties
Setting SP Advanced Power Capping Policy to Enforce Power Limit
Setting SP Power Management Settings for Power Policy (SPARC)
Setting the CMM Power Supply Redundancy Policy
Performing Oracle ILOM Maintenance and Configuration Management Tasks
Performing Firmware Updates
Reset Power to Service Processor or Chassis Monitoring Module
Backing Up, Restoring, or Resetting the Oracle ILOM Configuration
Maintaining x86 BIOS Configuration Parameters
BIOS Configuration Management
Performing BIOS Configuration Tasks From Oracle ILOM
SAS Zoning Chassis Blade Storage Resources
Zone Management for Chassis-Level SAS-2 Capable Resources
Manageable SAS-2 Zoning-Capable Devices
Sun Blade Zone Manager Properties
Important SAS Zoning Allocations Considerations
Enabling Zoning and Creating SAS-2 Zoning Assignments
Managing Existing SAS-2 Storage Resource Allocations
Resetting Sun Blade Zone Manager Allocations to Factory Defaults
Resetting the Zoning Password to Factory Default for Third-Party In-Band Management
User's Guide
Oracle ILOM Overview
About Oracle ILOM
Oracle ILOM Features and Functionality
Supported Management Interfaces
Supported Operating System Web Browsers
Integration With Other Management Tools
Getting Started With Oracle ILOM 3.1
Navigating the Redesigned 3.1 Web Interface
Navigating the Command-Line Interface (CLI) Namespace Targets
Collecting System Information, Monitoring Health Status, and Initiating Host Management
Collecting Information, Status, and Initiating Common Actions
Administering Open Problems
Administering Service Actions: Oracle Blade Chassis NEMs
Managing Oracle ILOM Log Entries
Performing Commonly Used Host Management Actions (Web)
Applying Host and System Management Actions
Administering Host Management Configuration Actions
Administering System Management Configuration Actions
Troubleshooting Oracle ILOM Managed Devices
Network Connection Issues: Oracle ILOM Interfaces
Tools for Observing and Debugging System Behavior
Enabling and Running Oracle ILOM Diagnostic Tools
Real-Time Power Monitoring Through Oracle ILOM Interfaces
Monitoring Power Consumption
View Power Consumption Properties for a Managed Device
Power Consumption Terminology and Properties
Monitoring Power Allocations
View the Power Allocation Plan for a Managed Device
Power Allocated Components and Monitoring Considerations
Analyzing Power Usage Statistics
Rolling Average Power Statistics Graphs and Metrics
View Power Statistics Bar Graphs and Metrics
Comparing Power History Performance
Power History Graphs and Metrics
View Power History Graphs and Metrics
Managing Oracle Hardware Faults Through the Oracle ILOM Fault Management Shell
Protecting Against Hardware Faults: Oracle ILOM Fault Manager
Using fmadm to Administer Active Oracle Hardware Faults
Using fmdump to View Historical Fault Management Logs
Using fmstat to View the Fault Management Statistics Report
Using the Command-Line Interface
About the Command-Line Interface (CLI)
CLI Reference For Supported DMTF Syntax, Command Verbs, Options
CLI Reference For Executing Commands to Change Properties
CLI Reference For Mapping Management Tasks to CLI Targets
CLI Reference
Basic CLI Command Reference for Oracle ILOM 3.1
System Information and Management
Host and System Control
Oracle ILOM Initial Setup
System Monitoring and Status
System Inventory
Oracle ILOM Configuration Management
Oracle ILOM Help
SNMP, IPMI, CIM, WS-MAN Protocol Management
SNMP Overview
About Simple Network Management Protocol
SNMP Components
Oracle ILOM SNMP MIBs
SNMP Command-Line Syntax Examples
Configuring SNMP Settings in Oracle ILOM
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (CLI)
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (Web)
Downloading SNMP MIBs Using Oracle ILOM
Manage User Accounts Using SNMP
Before You Begin – User Accounts (SNMP)
Configuring Oracle ILOM User Accounts (SNMP)
Configuring Oracle ILOM for Active Directory (SNMP)
Manage DNS Name Server Settings (SNMP)
Configuring Oracle ILOM for LDAP (SNMP)
Configuring Oracle ILOM for LDAP/SSL (SNMP)
Configuring Oracle ILOM for RADIUS (SNMP)
Manage Component Information and Email Alerts (SNMP)
Before You Begin – Component Information (SNMP)
Viewing Component Information (SNMP)
Managing Clock Settings, Event Log, Syslog Receiver, and Alert Rules (SNMP)
Configuring SMTP Client for Email Alert Notifications (SNMP)
Configuring Email Alert Settings (SNMP)
Monitor and Manage System Power (SNMP)
Before You Begin – Power Management (SNMP)
Monitoring the Power Consumption Interfaces (SNMP)
Maintaining System Power Policy (SNMP)
Managing System Power Properties (SNMP)
Manage Oracle ILOM Firmware Updates (SNMP)
Update Oracle ILOM Firmware (SNMP)
Manage Oracle ILOM Backup and Restore Configurations (SNMP)
View and Configure Backup and Restore Properties (SNMP)
Manage SPARC Diagnostics, POST, and Boot Mode Operations (SNMP)
Before You Begin – Manage SPARC Hosts (SNMP)
Managing SPARC Diagnostic, POST, and Boot Mode Properties (SNMP)
Server Managment Using IPMI
Intelligent Platform Management Interface (IPMI)
Configuring the IPMI Service
Using IPMItool to Run ILOM CLI Commands
Performing System Management Tasks (IPMItool)
IPMItool Utility and Command Summary
Server Management Using WS-Management and CIM
WS-Management and CIM Overview
Configuring Support for WS-Management in Oracle ILOM
Supported DMTF SMASH Profiles, CIM Classes and CIM Indications
Oracle's Sun-Supported CIM Classes
Document Conventions for Oracle's Sun-Supported CIM Classes
Oracle_AssociatedIndicatorLED
Oracle_AssociatedSensor
Oracle_Chassis
Oracle_ComputerSystem
Oracle_ComputerSystemPackage
Oracle_Container
Oracle_ElementCapabilities
Oracle_ElementConformsToProfile
Oracle_EnabledLogicalElementCapabilities
Oracle_HWCompErrorOkIndication
Oracle_IndicatorLED
Oracle_InstCreation
Oracle_InstDeletion
Oracle_LogEntry
Oracle_LogManagesRecord
Oracle_Memory
Oracle_NumericSensor
Oracle_PhysicalAssetCapabilities
Oracle_PhysicalComponent
Oracle_PhysicalElementCapabilities
Oracle_PhysicalMemory
Oracle_PhysicalPackage
Oracle_Processor
Oracle_ProcessorChip
Oracle_Realizes
Oracle_RegisteredProfile
Oracle_RecordLog
Oracle_ReferencedProfile
Oracle_Sensor
Oracle_SpSystemComponent
Oracle_SystemDevice
Oracle_ThresholdIndication
Oracle_UseOfLog
SNMP Command Examples
snmpget Command
snmpwalk Command
snmpbulkwalk Command
snmptable Command
snmpset Command
snmptrapd Command
Feature Updates and Release Notes
Feature Enhancements as of Oracle ILOM 3.1
Feature Enhancements Summary
Updates to Oracle ILOM 3.1.x Firmware
Initial 3.1 Point Releases for Servers and Sun Blade 6000 CMM
Deprecation Notice for WS-Man as of Oracle ILOM 3.2.1
Oracle ILOM 3.1 Known Issues
Documentation Titles in Translated Documents
Glossary
Index
Power Allocation Plan Properties per Managed Device
Table 83 System Power Specification Properties (Power Allocation)
Po wer S upply Maximum (/SP|CMM/powermgmt available_power) |
The
Power Supply Maximum property value, shown in Oracle ILOM interfaces, represents the maximum input power
wattage that the power supplies are capable of drawing from the power outlets. |
Redunda nt
Po wer (/CMM/powermgmt redundant_power) |
CMM |
The Redundant Power property value, shown in Oracle ILOM interfaces, represents the available power
wattage currently not allocated to the blade chassis power supplies.
Installed Hardw are Min imum |
Blade SP |
The Installed Hardware Minimum property value, shown
in Oracle ILOM web interface, represents the minimum input power wattage consumed by the
hardware components installed on the server. |
Peak Perm itted (/SP|CMM/powermgmt permitted_power) |
The Peak Permitted property value,
shown in Oracle ILOM interfaces, represents the maximum power wattage consumption guaranteed to
the managed device. For instance:
For Oracle x86 and SPARC servers, the Peak Permitted property represents the maximum input power wattage that the server can consume at any instant.
For Oracle CMMs, the Peak Permitted property represents the maximum input power wattage a blade server can consume at any instant.
Important monitoring considerations:
Not all Oracle x86 server SPs support the property for Target Limit in the Oracle ILOM interfaces. In these instances, the same property value (wattage) shown for Peak Permitted is derived by the power consuming hardware components installed on the managed server.
For a server SP, Oracle ILOM derives the wattage value shown for Peak Permitted from the property values shown for Allocated Power and Target Limit. If the Target Limit property is not supported, Oracle ILOM derives the Peak Permitted property value from the power consuming hardware components installed on the managed server.
For further information about budgeting power that is consumed by
a managed device, refer to Configuration and Maintenance, Setting Power Alert Notifications and Managing System Power Usage. |
Allocated Po wer (/SP|CMM/powermgmt allocated_power) |
The Allocated Power property value,
shown in Oracle ILOM interfaces, represents the maximum input power wattage allocated to
a managed device. For example:
For an Oracle rackmounted server, the Allocated Power property value represents the total sum of the maximum power allocated to all installed chassis components and hot-pluggable components configured on the rackmount server.
For an Oracle blade chassis, the Allocated Power property value represents: 1) the maximum power wattage that is allocated to all installed chassis components, and 2) the maximum power wattage granted to all chassis server blades.
Target Limit (/SP/powermgmt/budget powerlimit) |
The Target Limit property value, shown
in Oracle ILOM interfaces, displays the power limit value (wattage or percentage) configured on
the server. Important power monitoring considerations:
Oracle ILOM uses the set power limit value to determine the power budgeting parameters allowed for an Oracle server.
When a power limit is not configured in Oracle ILOM, the read-only Target Limit property value Not Configured appears in the Power Allocation Plan.
Not all Oracle x86 server SPs support a Target Limit property in Oracle ILOM interfaces. When a Target Limit property is not supported, Oracle ILOM will determine the Peak Permitted wattage value based on the power consuming hardware components installed on the managed server.
For more information about power budgeting or instructions for configuring a
power limit, refer to Configuration and Maintenance, Setting Power Alert Notifications and Managing System Power Usage. |
Table 84 Per Component Power Map Properties (SP Power Allocation)
Alloc ated Powe r (/SP/powermgmt allocated_power) |
The Allocated Power property value, shown in Oracle ILOM SP interfaces, represents the total
sum of power wattage allocated to either: 1) a server component category (CPUs),
or 2) an individual component installed on the server (MB_P0). |
A Yes or No property value, per server component, appears in
the Oracle ILOM SP web interface to indicate whether a power budget limit
can be set for that server component.
Note - If power budgeting (Target Limit
property) is not supported by the managed server, the “Can be capped” property will
not appear in the Power Management Allocation Plan.
power budgeting, refer to Configuration and Maintenance, Setting Power Alert Notifications and Managing System Power Usage. |
Table 85 Blade Slot Power Summary (CMM Power Allocation)
Grantable Power (/CMM/powermgmt grantable_power) |
CMM blade
slot |
The Grantable Power property value, shown in the Oracle ILOM CMM interface, represents the
remaining power wattage that the CMM can allocate to the blade chassis slots
without exceeding the grant limit. |
CMM blade slot |
The Unfilled Grant Requests property value,
shown in the Oracle ILOM CMM web interface, represents the ungranted power wattage
that the CMM has been requested to grant to the chassis blade slots. |
Table 86 Blade Power Grants (CMM Power Allocation)
Grant L imit (/CMM/powermgmt/powerconf/bladeslots/BLn grant_limit) |
CMM blade slot |
Require d Power (/CMM/powermgmt/advanced/n value) |
CMM blade slot |
The read-only
Required Power property value, shown in Oracle ILOM CMM interfaces, represents the maximum sum
of power wattage required for either: 1) all blade slots, or 2) an
individual blade slot. |
Grante d Power (/CMM/powermgmt/powerconf/bladeslots granted_power or /CMM/powermgmt/powerconf/bladeslots/BLn granted_power |
CMM blade slot |
The read-only Granted Power property value, shown in
the Oracle ILOM CMM interfaces, represents the maximum sum of power wattage the
CMM has granted to either: 1) all blade slots requesting power, or 2)
an individual blade slot requesting power. |
Table 87 Chassis Component Properties (CMM only)
Allocated Pow er (CMM/powermgmt/powerconf/component_type/component_name allocated_power) |
CMM component |
The
read-only Allocated Power property value, shown in Oracle ILOM CMM interfaces, represents the total sum
of power wattage allocated to either: 1) an Oracle blade chassis category (fans),
or 2) an individual chassis component installed (fan0).
Note - If the Oracle blade chassis configuration
supports I/O blade servers, Oracle ILOM will also display the maximum sum of power
wattage reserved for all I/O blade servers.
