Go to main content
Sun Network QDR InfiniBand Gateway Switch Product Notes for Firmware Version 2.1
Exit Print View
Updated: March 2017
README File Is Incomplete
The README file accompanying the 2.1.2-2 firmware available for download from My Oracle Support is lacking this list of bugs fixed in the 2.1.2-2 firmware. The README file accompanying the 2.1.3-4 through 2.1.9-1 firmware is correct and inclusive of these bugs.
  • 15787181 – Segmentation fault in osm_mgrp_delete_port()
  • 15809823 – Subnet Manager should have a lease time of 60 seconds
  • 15810464 – getmaster CLI command should show local SM state
  • 15957702 – Switch running master Subnet Manager should trigger handover at reboot
  • 15805689 – Default high error rate threshold should be increased to 3456 symbol errors per 24h
  • 15815591 – BridgeX and I4 firmware versions should be checked by fwverify
  • 15810720 – Do not allow to create partition without specifying P_Key
