Go to main content
Sun Network QDR InfiniBand Gateway Switch Product Notes for Firmware Version 2.1
Exit Print View
Updated: March 2017
disablegwport Command Connector Invalid
In the Sun Network QDR InfiniBand Gateway Switch documentation and in the help and usage provided by the disablegwport command itself, the 0A-ETH and 1A-ETH connector names are valid as command variables. This is incorrect. Only these connector names are valid as command variables:
  • 0A-ETH-1, 0A-ETH-2, 0A-ETH-3, 0A-ETH-4
  • 1A-ETH-1, 1A-ETH-2, 1A-ETH-3, 1A-ETH-4
Do not use 0A-ETH or 1A-ETH as command variables for the disablegwport command.
