For SIGURG and SIGIO, each socket has a process number and a process group ID. These values are initialized to zero, but can be redefined at a later time with the F_SETOWN fcntl(2) command, as in the previous example. A positive third argument to fcntl(2) sets the socket's process ID. A negative third argument to fcntl(2) sets the socket's process group ID. The only allowed recipient of SIGURG and SIGIO signals is the calling process. A similar fcntl(2), F_GETOWN, returns the process number of a socket.
You can also enable reception of SIGURG and SIGIO by using ioctl(2) to assign the socket to the user's process group.
/* oobdata is the out-of-band data handling routine */ sigset(SIGURG, oobdata); int pid = -getpid(); if (ioctl(client, SIOCSPGRP, (char *) &pid) < 0) { perror("ioctl: SIOCSPGRP"); }
