cc [ flag... ] file... –lgss [ library... ]
#include <gssapi/gssapi.h>
OM_uint32 gss_display_status(OM_uint32 *minor_status,
OM_uint32 status value,int status type,
const gss_OID mech_type, OM_uint32 *message_context,
gss_buffer_t status string);
The gss_display_status() function enables an application to obtain a textual representation of a GSS-API status code for display to the user or for logging purposes. Because some status values may indicate multiple conditions, applications may need to call gss_display_status() multiple times, with each call generating a single text string.
The message_context parameter is used by gss_acquire_cred() to store state information on error messages that are extracted from a given status_value. The message_context parameter must be initialized to 0 by the application prior to the first call, and gss_display_status() will return a non-zero value in this parameter if there are further messages to extract.
The message_context parameter contains all state information required by gss_display_status() to extract further messages from the status_value. If a non-zero value is returned in this parameter, the application is not required to call gss_display_status() again unless subsequent messages are desired.
The parameter descriptions for gss_display_status() follow:
Status code returned by the underlying mechanism.
Status value to be converted.
If the value is GSS_C_GSS_CODE, status_value is a GSS-API status code. If the value is GSS_C_MECH_CODE, then status_value is a mechanism status code.
Underlying mechanism that is used to interpret a minor status value. Supply GSS_C_NO_OID to obtain the system default.
Should be initialized to zero prior to the first call. On return from gss_display_status(), a non-zero status_value parameter indicates that additional messages may be extracted from the status code by means of subsequent calls to gss_display_status (), passing the same status_value, status_type, mech_type, and message_contextparameters.
Textual representation of the status_value. Storage associated with this parameter must be freed by the application after use with a call to gss_release_buffer(3GSS).
The gss_display_status() function may return the following status codes:
Successful completion.
Indicates that translation in accordance with an unsupported mechanism type was requested.
The status value was not recognized, or the status type was neither GSS_C_GSS_CODE nor GSS_C_MECH_CODE.
The underlying mechanism detected an error for which no specific GSS status code is defined. The mechanism-specific status code reported by means of the minor_status parameter details the error condition.
gss_acquire_cred(3GSS), gss_release_buffer(3GSS), attributes(5)
