man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
sip_conn_destroyed(3SIP)
Name
sip_init_conn_object, sip_clear_stale_data, sip_conn_destroyed - connection object related functions
Synopsis
cc [ flag ... ] file ... –lsip [ library ... ]
#include <sip.h>
int sip_init_conn_object(sip_conn_object_t obj);
void sip_clear_stale_data(sip_conn_object_t obj);
void sip_conn_destroyed(sip_conn_object_t obj);
Description
The sip_init_conn_object() function initializes the connection object obj for use by the stack. The first member of the connection object (a void *) is used by the stack to store connection object specific stack-private data.
The sip_clear_stale_data() function is used to clear any stack-private data in the connection object obj.
The sip_conn_destroyed() function is used to intimate the stack of the pending destruction of the connection object obj. The stack clean up any stack-private data in obj and also removes obj from any caches the stack maintains.
Return Values
The sip_init_conn_object() function returns 0 on success and the appropriate error value on failure.
The value of errno is not changed by these calls in the event of an error.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
libsip(3LIB)
