Go to main content
Oracle® ILOM Security Guide For Firmware Releases 3.x and 4.x
Exit Print View
Updated: May 2019
Set Physical Presence Check
Before You Begin
  • The Physical Presence Check mode in Oracle ILOM is enabled by default.
  • Firmware version 3.1 or later is required to use the Physical Presence Check mode in Oracle ILOM.
  1. In the Oracle ILOM web interface, click ILOM Administration -> Identification
  2. In the Identification page, navigate to the Physical Presence Check property, and then perform one of the following:
    • Select the Physical Presence check box to enable. When enabled, the Locator button on the physical system must be pressed in order to recover the default Oracle ILOM password.
      -or-
    • Clear the Physical Presence check box to disable. When disabled, the default Oracle ILOM administrator root password can be reset without pressing the Locator button on the physical system.
  3. Click Save to apply the change.
Related Information
