Before You Begin
Review the following tables to determine which protocol services and network ports are enabled or disabled by default in Oracle ILOM.
Figure 4, Table 4, Services and Ports Enabled by Default Services and Ports Enabled by Default
Figure 5, Table 5, Services and Ports Disabled by Default Services and Ports Disabled by Default
The Admin (a) role is required in Oracle ILOM to modify the State property of protocol services.
Follow these steps to modify the State property of a network service.
For instance, in the:
Note that disabling the State property of a protocol service results in closing the respective protocol service network port, and preventing the use of the protocol service with Oracle ILOM.
Management Services and Network Default Properties, Oracle ILOM Administrator's Guide for Configuration and Maintenance (Firmware 3.2.x)
Management Services and Network Default Properties, Oracle ILOM 3.1 Configuration and Maintenance Guide
Configuring Network Settings, Oracle ILOM 3.0 Daily Management - CLI Procedures Guide
Configuring Network Settings, Oracle ILOM 3.0 Daily Management - Web Procedures Guide
