Classifying and Conditioning Ingress Traffic
Define an ACL and Access Group
Define Incoming Packet Priorities
Define the Traffic Classes With the class-map Command
Set the Rate and Burst Tolerance of a Traffic Stream
Classifying and Scheduling Egress Class Traffic
Define the Egress Scheduler Behavior
You can define TCP and UDP traffic from a given subnet. Both rules are applied to interface 0/2. This application enables traffic to be separated from one port into two classes, then enqueued to separate queues on egress.
SEFOS# configure terminal SEFOS(config)# ip access-list extended 101 SEFOS(config-ext-nacl)# permit tcp 10.123.1.0 255.255.255.0 any SEFOS(config-ext-nacl)# exit SEFOS(config)# ip access-list extended 102 SEFOS(config-ext-nacl)# permit udp 10.123.1.0 255.255.255.0 any SEFOS(config-ext-nacl)# exit SEFOS(config)# ip access-list extended 110 SEFOS(config-ext-nacl)# permit ip any any SEFOS(config-ext-nacl)# exit SEFOS(config)# interface extreme-ethernet 0/2 SEFOS(config-if)# ip access-group 101 in SEFOS(config-if)# ip access-group 102 in SEFOS(config-if)# ip access-group 110 in SEFOS(config-if)# end
SEFOS# show access-lists ip 101 Extended IP Access List 101 ----------------------------- Filter Priority : 1 Filter Protocol Type : TCP IP address Type : IPV4 Source IP address : 10.123.1.0 Source IP address mask : 255.255.255.0 Source IP Prefix Length : 24 Destination IP address : 0.0.0.0 Destination IP address mask : 0.0.0.0 Destination IP Prefix Length : 0 Flow Identifier : 0 In Port List : Ex0/2 Out Port List : NIL Filter TOS : NIL Filter DSCP : NIL Filter Source Ports From : 0 Filter Source Ports Till : 65535 Filter Destination Ports From : 0 Filter Destination Ports Till : 65535 Filter Action : Permit Status : Active
SEFOS# show access-lists ip 102 Extended IP Access List 102 ----------------------------- Filter Priority : 1 Filter Protocol Type : UDP IP address Type : IPV4 Source IP address : 10.123.1.0 Source IP address mask : 255.255.255.0 Source IP Prefix Length : 24 Destination IP address : 0.0.0.0 Destination IP address mask : 0.0.0.0 Destination IP Prefix Length : 0 Flow Identifier : 0 In Port List : Ex0/2 Out Port List : NIL Filter TOS : NIL Filter DSCP : NIL Filter Source Ports From : 0 Filter Source Ports Till : 65535 Filter Destination Ports From : 0 Filter Destination Ports Till : 65535 Filter Action : Permit Status : Active
SEFOS# show access-lists ip 110 Extended IP Access List 110 ----------------------------- Filter Priority : 1 Filter Protocol Type : ANY IP address Type : IPV4 Source IP address : 0.0.0.0 Source IP address mask : 0.0.0.0 Source IP Prefix Length : 0 Destination IP address : 0.0.0.0 Destination IP address mask : 0.0.0.0 Destination IP Prefix Length : 0 Flow Identifier : 0 In Port List : Ex0/2 Out Port List : NIL Filter TOS : NIL Filter DSCP : NIL Filter Action : Permit Status : Active
