Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
QoS Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Configuration Overview
QoS Management Architecture
Configuring QoS
Introduction
Classifying and Conditioning Ingress Traffic
Introduction
Define an ACL and Access Group
Define TCP and UDP Traffic
Define VLAN Tagged Packets
Define Incoming Packet Priorities
Define the Traffic Classes With the class-map Command
Set the Rate and Burst Tolerance of a Traffic Stream
Set up the Ingress Policy
Classifying and Scheduling Egress Class Traffic
Define the Egress Scheduler Behavior
Define a General Shaper
Insatiate Egress Queues
Mapping Ingress Traffic to Egress Class
Map Ingress Traffic to Egress Class
Configuring QoS
These topics explain how to configure QoS on a Sun Blade 6000 Ethernet Switched NEM 24p 10GbE.
