Classifying and Conditioning Ingress Traffic
Define an ACL and Access Group
Define the Traffic Classes With the class-map Command
Set the Rate and Burst Tolerance of a Traffic Stream
Classifying and Scheduling Egress Class Traffic
Define the Egress Scheduler Behavior
You can define the priority of incoming packets by using the priority-map command so that incoming packets are tagged with a defined priority. You can use the map interface command to define the interface.
SEFOS# configure terminal SEFOS(config)# priority-map 500 SEFOS(config-pri-map)# map interface extreme-ethernet 0/4 in-Priority-type vlanPri in-priority 5 regen-priority 3 SEFOS(config-pri-map)# exit SEFOS(config)# exit
SEFOS# show priority-map 500 QoS Priority Map Entries ------------------------ PriorityMapId : 500 IfIndex : Ex0/4 VlanId : 0 InPriorityType : VlanPriority InPriority : 5 RegenPriority : 3 InnerRegenPriority : None
You can use any of the preceding CLIs to define a packet stream. You must define each traffic stream with an interface. After you define a packet stream, you must map it into a traffic class for QoS management. You do this with the class-map command.
