Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LLDP Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Configuring LLDP
Configuration Topology
Configuration Guidelines
Default Settings
Configure the LLDP System Control Status
Configure the LLDP Module Status
Configure LLDP Global Objects
Configure the LLDP Admin Status
Enable LLDP Optional TLVs
Enabling a Specific Management Address
Enable a New IP Address
Enable an Existing IP Interface
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable a New VLAN Name
Enable an Existing VLAN Name
Enable a Particular PPVID
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
Clear the LLDP Traffic Counters
Clear the LLDP Remote Table
View LLDP Errors
Configure LLDP Trace Options
By default, the LLDP admin status is set to transmit and receive (TxAndRx). You can change the LLDP admin status to change LLDP operational mode to any of the following values:
  1. At both switches, view the LLDP default values of the admin status.
    SEFOS# show lldp interface
    Ex0/1:
    Tx State            : Enabled
    Rx State            : Enabled
  2. At switch 1, configure the LLDP admin status as transmit only (TxOnly).
    SEFOS# configure terminal
    SEFOS(config)# interface extreme-ethernet 0/1
    SEFOS(config-if)# no lldp receive
    SEFOS(config-if)# exit
    SEFOS(config)# end
  3. Review the LLDP admin status.
    SEFOS# show lldp interface extreme-ethernet 0/1
    Ex0/1:
    Tx State            : Enabled
    Rx State            : Disabled
  4. At switch 2, configure the LLDP admin status as receive only (RxOnly).
    SEFOS(config-if)# no lldp transmit
    SEFOS(config)# end
  5. Review the configured LLDP admin status.
    Ex0/1:
    Tx State            : Disabled
    Rx State            : Enabled
  6. At both switches, set the LLDP admin status to Disabled.
    SEFOS(config)# end
  7. Review the configured LLDP admin status.
    Ex0/1:
    Tx State            : Disabled
    Rx State            : Disabled
