Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LLDP Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Configuring LLDP
Configuration Topology
Configuration Guidelines
Default Settings
Configure the LLDP System Control Status
Configure the LLDP Module Status
Configure LLDP Global Objects
Configure the LLDP Admin Status
Enable LLDP Optional TLVs
Enabling a Specific Management Address
Enable a New IP Address
Enable an Existing IP Interface
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable a New VLAN Name
Enable an Existing VLAN Name
Enable a Particular PPVID
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
Clear the LLDP Traffic Counters
Clear the LLDP Remote Table
View LLDP Errors
Configure LLDP Trace Options
This section describes how to configure the LLDP system control status, which is set to Start by default. You must set the LLDP system control status to Start before you make any configuration changes in LLDP.
  1. In switch 1, shut down LLDP.
    SEFOS# configure terminal
    SEFOS(config)# shutdown lldp
    SEFOS(config)# end
  2. View the LLDP system control status.
    SEFOS# show lldp
    % Lldp Module is shutdown
  3. Start LLDP.
    SEFOS(config)# no shutdown lldp
    SEFOS(config)# end
    After the LLDP system control status is changed to Start, LLDP global configuration objects are set with default values.
  4. View the default values for the global configuration objects of LLDP.
    SEFOS# show lldp
    LLDP is disabled
    Transmit Interval        : 30
    Holdtime Multiplier        : 4
    Reinitialization Delay    : 2
    Tx Delay            : 2
    Notification Interval    : 5
    Chassis Id SubType        : Mac Address
    Chassis Id            : 00:01:02:03:04:01
