Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LLDP Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Configuring LLDP
Configuration Topology
Configuration Guidelines
Default Settings
Configure the LLDP System Control Status
Configure the LLDP Module Status
Configure LLDP Global Objects
Configure the LLDP Admin Status
Enable LLDP Optional TLVs
Enabling a Specific Management Address
Enable a New IP Address
Enable an Existing IP Interface
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable a New VLAN Name
Enable an Existing VLAN Name
Enable a Particular PPVID
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Configure the LLDP Port-ID Subtype
Enable the LLDP Notification Status or Type
Clear the LLDP Traffic Counters
Clear the LLDP Remote Table
View LLDP Errors
Configure LLDP Trace Options
This section describes how to configure basic optional TLVs for transmission when the transmission status is set to Disabled by default. The following optional TLVs are in LLDP:
To enable the LLDP optional TLVs, perform the following steps:
  1. At both switches, enable basic optional TLVs.
    SEFOS# configure terminal
    SEFOS(config)# interface extreme-ethernet 0/1
    SEFOS(config-if)# lldp tlv-select basic-tlv port-descr sys-name-sys-descr sys-capab mgmt-addr all
    SEFOS(config)# end
  2. At switch 1, review the local system information.
    SEFOS# show lldp local extreme-ethernet 0/1
    Port Id SubType            : Interface Alias
    Port Id                : Slot0/1
    Port Description            : Ethernet Interface
    Enabled Tx Tlvs            : Port Description, System Name,
                        System Description, System Capability,                             Management Address
  3. Review the local management address.
    SEFOS# show lldp local mgmt-addr
    Management Address            TxEnabledPorts
    12.0.0.1                Ex0/1
  4. At switch 2, review the information about learned neighbors.
    SEFOS# show lldp neighbors ex 0/1 detail
    System Name                : name_of_system
    System Desc                : SNMPV2
    Local Intf                : Ex0/1
    Time Remaining            : 96 Seconds
    System Capabilities Supported    : B,R
    System Capabilities Enabled    : B,R
    Management Addresses        :
    IfId        SubType    Address            OID
    1009        IPv4        12.0.0.1            1 3 6 1 2 1 2 2 1 1
