| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System LLDP Administration Guide |
Configure the LLDP System Control Status
Configure the LLDP Module Status
Configure the LLDP Admin Status
Enabling a Specific Management Address
Enable an Existing IP Interface
Enable IEEE 802.1 Organizationally-Specific TLVs
Enabling a Particular VLAN Name
Enable IEEE 802.3 Organizationally-Specific TLVs
Disable LLDP Basic Optional TLVs
Disable IEEE 802.1 Organizationally-Specific TLVs
Disable the IEEE 802.3 Organizationally-Specific TLVs
Configure the LLDP Chassis-ID Subtype
Enable the LLDP Notification Status or Type
You can configure the port-ID subtype with any of the following values:
Interface alias
Port component
MAC address
Network address
Intereface name
Local
While configuring the port-ID subtype as the port component or local setting, you must provide an input string in the command for setting the port ID.
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/1 SEFOS(config-if)# lldp port-id-subtype mac-addr SEFOS(config-if)# exit SEFOS(config)# set lldp enable SEFOS(config)# end
SEFOS# show lldp local extreme-ethernet 0/1 Port Id SubType : Mac Address Port Id : 00:01:02:03:04:01 ...
SEFOS# show lldp neighbors extreme-ethernet 0/1 detail ... Port Id SubType : Mac Address Port Id : 00:01:02:03:04:01 ...
